I found this in the c:\pbp3\readme.txt file:
Release Notes:
-------------------------------------3.0.5--------------------------------------
Fixed BLOCK_SIZE for 16(L)F1826/1827
Fixed configuration defaults for 12(L)F752 to match MPASM 5.44
Legacy SFR names restored for many devices
New Parts: 12F1501, 16F1503, 16F1508, 16F1509, 16F1512, 16F1513
... so I'm assuming that means I have 3.0.5 (I only bought the PBP3 upgrade last month).
I'll be using HPWM with a motor, but right now I just want to see it working with an LED. I've tried using CCP1 (which is an EECP) and CCP3, but no luck; the LED is just dimly lit no matter what Duty Cycle I use:
(note that I used the example from the link above, but I'd really like to just use HPWM as my interrupt routine is going to modify the motor's speed via the HPWM duty cycle and that worked really well with the 16F628A)Code:DEFINE OSC 20 ' Set oscillator 20Mhz ' *************************************************************** ' Device Fuses ' *************************************************************** ' PIC chip data sheets can be found here: C:\Program Files\Microchip\MPASM Suite #CONFIG __config _CONFIG1, _FOSC_HS & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF __config _CONFIG2, _LVP_OFF #ENDCONFIG DEFINE CCP3_REG PORTA DEFINE CCP3_BIT 2 ANSELA = %00000000 ' Digital only (PortA) ANSELC = %00000000 ' Digital only (PortC) ADCON1 = $0F TRISA = %00000000 ' Make all pins on PortA output TRISC = %00000000 ' Make all pins on PortC output DUTY3 var word ' Set CCP modules to PWM mode CCP3CON = %00001100 ' Mode select = PWM PR2 = $FF '255 T2CON = %00000110 ' TMR2 on 1:!6 prescale DUTY3 = 512 CCP3CON.4 = DUTY3.0 CCP3CON.5 = DUTY3.1 CCPR3L = DUTY3 >> 2 lblLoop: goto lblLoop end
