Convert Rotary Encoder Code from 16F628A to 16F1825
Results 1 to 28 of 28
    In the version history for PBP3 ... http://support.melabs.com/content/29...ersion-History
    One of the bug fixes listed is ... Fixed HPWM compile error for Enhanced Mid-Range parts in which CCPTMRS0 doesn't exist.
    Default Re: Convert Rotary Encoder Code from 16F628A to 16F1825
    Ah! So what you're saying is, use PBP3 already I did purchase the software upgrade but haven't tried converting my existing PBP code yet. Guess I should start sooner than later.
    This code works on a PIC 16F628A:
    '---------Initialization--------
    DEFINE OSC 20            ' set oscillator 20Mhz
    ' Device Fuses
           __config _HS_OSC & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON & _LVP_OFF & _CP_OFF & _CPD_OFF
    CMCON    = 7    	 ' Turn off comparators
    TRISA    = %00000000 ' Make all PortA pins output
    TRISB    = %00110000 ' Make PortB pins 4-5 input
    Old_Bits       VAR BYTE
    New_Bits       VAR BYTE
    RotEncDir      VAR BIT   ' 1=CW, 0=CCW
                             ' Rot Enc pin A connected to PortB.5;
                             ' Rot Enc pin B connected to PortB.4
    Old_RPM        VAR BYTE
    I              VAR BYTE
    ' SETUP YOUR LCD HERE!!!
    ;Define LCD_DREG PORTA
    ;Define LCD_DBIT 0
    ;Define LCD_RSREG PORTA
    ;define LCD_RSBIT 4
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 7            ' Use PortB.7 as the Enable (E) bit since PortB.3
                                 ' on the 16F628A is the one-and-only HPWM output
    ;define LCD_BITS 4
    ;define LCD_LINES 2
    ;define LCD_COMMANDUS 2000
    ;define LCD_DATAUS 50
    '---------Includes----------
    INCLUDE "EE_Vars.PBP"       ' Requires MPASM assembler
                                ' Go to "View > Compile and Program Options..."
                                ' On "Assembler" tab, check "Use MPASM"
                                ' (no need to change any of the default settings)
                                ' --> copy file to PBP main folder (i.e. c:\pbp)
    MotorRPM VAR BYTE  :  @  EE_var  _MotorRPM, BYTE, 50
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
                                 ' --> copy both files to PBP main folder
                                 ' (i.e. c:\pbp)
    INT_LIST  macro    ; IntSource,         Label,  Type, ResetFlag?
            INT_Handler    RBC_INT,  _Rot_Encoder,   PBP,  yes
        INT_CREATE     ; Creates the interrupt processor
    @ INT_ENABLE   RBC_INT     ;RB Port Change Interrupt
    ' Set default values
    Old_Bits = PORTB & (%00110000)
    Old_RPM = MotorRPM
    LCDOUT $FE, 1
    PAUSE 1000
    rpmAdj CON 20       ' PWM cycle seems to be "higher" than HPWM, so need
                        ' to reduce PWM cycle max to be less than HPWM cycle value
    ' Spin up motor to saved value of _MotorRPM
    IF MotorRPM > rpmAdj Then
        FOR i = 0 to (MotorRPM - rpmAdj)
            PWM PortB.3, I, 100
        NEXT I
    EndIf
    ' Begin background HPWM
    GOSUB motorhpwm
        IF MotorRPM <> Old_RPM Then
            Old_RPM = MotorRPM
            GOSUB motorhpwm
    @ EE_write_var _MotorRPM        ; save the new number to EEPROM
        EndIF
        LCDOUT $FE, 2, "MotorRPM: ", #MotorRPM, "   "
        pause 10
        GOTO Main
    motorhpwm:
        HPWM 1, MotorRPM, 20000 ; Tried 245 Hz but it made the motor too loud.
                                ; Supposedly, anything above 20kHz is above
                                ; human hearing
    '---[RBC - interrupt handler]---------------------------------------------------
    Rot_Encoder:
        New_Bits = PORTB & (%00110000)
        IF (New_Bits & %00110000) = (Old_Bits & %00110000) Then DoneRotEnc
        RotEncDir = New_Bits.5 ^ Old_Bits.4
        IF RotEncDir = 1 Then
            ; CW rotation - increase speed but only to a max of 255
            IF MotorRPM < 255 then MotorRPM = MotorRPM + 1
        Else
            ' CCW rotation - decrease speed to a min of 0
            IF MotorRPM > 0 Then MotorRPM = MotorRPM - 1
        EndIF
    DoneRotEnc:
        Old_Bits = New_Bits
    @ INT_RETURN
    This code does NOT on a PIC 16F1825:
    ' Initialization
    DEFINE OSC 20            ' Set oscillator 20Mhz
    ' Device Fuses
    ' PIC chip data sheets can be found here: C:\Program Files\Microchip\MPASM Suite
           __config _CONFIG1, _FOSC_HS & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF
           __config _CONFIG2, _LVP_OFF
    ANSELA   = %00000000
    ANSELC   = %00000000
    TRISA    = %00000011     ' Make PortA pins 0-1 input for rotary encoder
    TRISC    = %00000000     ' Make all pins on PortC output
    Old_Bits       VAR BYTE
    New_Bits       VAR BYTE
    Old_RPM        VAR BYTE
    I              VAR BYTE
    ;Define LCD_DBIT 0
    ;define LCD_RSBIT 4
    ;DEFINE LCD_EREG PORTB
    ;DEFINE LCD_EBIT 7            ' Use PortB.7 as the Enable (E) bit since PortB.3
    ;define LCD_BITS 4
    ;define LCD_LINES 2
                                 ' (i.e. c:\pbp)
            INT_Handler    IOC_INT,  _Rot_Encoder,   PBP,  yes
    @ INT_ENABLE   IOC_INT     ; Interrupt-on-Change interrupt
    Old_Bits = PORTA & (%00000011)
    Old_RPM = MotorRPM
    ;LCDOUT $FE, 1
    ;PAUSE 1000
    IF MotorRPM > 1 THEN
        FOR i = 0 to MotorRPM
            HPWM 3, I, 20000
        NEXT I
    EndIf
            Old_RPM = MotorRPM
            GOSUB motorhpwm
        EndIF
    ;    LCDOUT $FE, 2, "MotorRPM: ", #MotorRPM, "   "
    ;    pause 10
        GOTO Main
    motorhpwm:
        HPWM 3, MotorRPM, 20000 ; Tried 245 Hz but it made the motor too loud.
                                ; human hearing
    ' [RBC - interrupt handler]
    Rot_Encoder:
        New_Bits = PORTA & (%00000011)
        IF (New_Bits & %00000011) = (Old_Bits & %00000011) Then DoneRotEnc
        RotEncDir = New_Bits.1 ^ Old_Bits.0
        Else
        EndIF
    DoneRotEnc:
        Old_Bits = New_Bits
    @ INT_RETURN
    (The motor spins at full speed and encoder changes are ignored).
    I've been at this most of the night - any ideas? Apart from the subtle change to spinning up the motor to the saved _MotorRPM EEPROM variable, I can't see what I'm doing wrong. Am I missing a register setting to tell it to use PWM on CCP3?
    I'll double check the connections, but can someone please confirm if I need this to enable the interrupt-on-change feature?
    INTCON.3 = 1        'IOCIE bit set to 1
    That doesn't explain why the HPWM doesn't work, though. Is there something that needs to be configured for PWM use of CCP3?
    Ross,
    The IOC interrupts work differently than the RBC interrupts on the 628A.
    To fully understand them, you'll need to read section 13.0 INTERRUPT-ON-CHANGE in the datasheet.
    But essentially each IOC pin operates independantly, with individual selection of rising/falling edges, and individual interrupt flags.
    Each pin must be enabled with edge selects, and the flags must be cleared on each interrupt.
    The registers you need to look at are ...
    IOCAP: INTERRUPT-ON-CHANGE PORTA POSITIVE EDGE REGISTERI
    IOCAN: INTERRUPT-ON-CHANGE PORTA NEGATIVE EDGE REGISTER
    IOCAF: INTERRUPT-ON-CHANGE PORTA FLAG REGISTER
    After being setup properly, you can use the interrupt flags to tell what pins changed, instead of reading the port and doing the newbits-oldbits stuff.
    If you don't clear the flags, you end up in a continuous interrupt loop and none of the rest of your program will execute.
    Thanks Darrel. IOC is definitely more complicated than the RBC interrupt but it's always good to learn new things
    This is the config I have so far:
    ANSELA   = %00000000     ' Digital only (PortA)
    ANSELC   = %00000000     ' Digital only (PortC)
    INTCON.3 = 1             ' Enable interrupt-on-change (IOCIE)
    IOCAP.0   = 1
    IOCAP.1   = 1
    IOCAN.0   = 1
    IOCAN.1   = 1
    IOCAF.0   = 0
    IOCAF.1   = 0
    Are you saying that for my PBP interrupt routine I can change the code to look at IOCAF.0 and IOCAF.1 values instead of the NewBits/OldBits? The values on A/B from the rotary encoder (incremental quadrature) are:
    CW
    00
    10
    11
    01
    CCW
    00
    01
    11
    10
    I think I still need to track the old values on A/B pins (RA1 & RA0 in my application) and do something like this pseudo code:
    If A caused the interrupt then
    Compare A & B
    If different then
    CW rotation
    Else
    CCW rotation
    End If
    End If
    If B caused the interrupt then
    Compare A & B
    If same then
    CW rotation
    Else
    CCW rotation
    End If
    End If
    Does that make sense?
