Does 16F628a support debugging or not?
Results 1 to 19 of 19
    Jun 2011
    Indian Harbour Nova Scotia
    Default Re: Does 16F628a support debugging or not?
    I hooked up the MAX232 circuit and using the loopback program can echo characters after a "normal" compile.
    After an ICD compile, typing the letter "h" returns $3C04B6.
    Selecting RUN on the ICD menu, pops up a box that says I'm not connected to the serial port, which of course is incorrect, since I can loopback typed characters.
    Getting closer!
    What is significance of the returned hex value (just curious)?
    Each time you compile a program for ICD, MicroCode Studio generates a new "handshake" number so that it can match the program in the chip to the program on the PC.
    After using Serial Communicator, be sure to Disconnect before trying to use the ICD in MCSP.
    MCSP cannot connect if Serial Communicator is using the port.
    Jun 2011
    Regarding the quote, I guess since I made lots of mistakes, I made SOMETHING.
    SUCCESS! I can ICD compile and debug my program on a 16F628a
    • I wasn't using the full config string as you had said is necessary because #CONFIG sets everything back to default.
    • My bad habit of doing this: TRISB=%0000000 instead of really looking at what the pins are doing got me. PortB.1 is Rx and is an input, not an output. I've been doing outputs-only for so long, it never dawned on me I'd need an input...
    Thanks again for your support and your suggestions. It made me really want to fix this thing to the point where I was anal about it. The advice you gave is much better than those who say, "RTFM".
    The serial loop back program was really good too because it allowed me to verify my circuit, comm from PC, comm to chip. Good stuff.
    Great!
    I'm glad you got it working.
    And I'm glad I could help.
