Just open your manual @ the ADC page ...
WHICH kind of parameter is used to select the input channel ???
Hi, Alain, thanks for replying. I tried the following as well from what I understood:
No Luck. Where am I going wrong. I did this before but only with 1 channel. That worked out well. Now never tried anything with two channels, so can't say much.Code:LoadTime: ADCON0=%10000100 : Pause 10 ADCIN Poten,Time : Pause 10 ; Time=(Time/4) DEBUG "TIME=",DEC Time,10 Return LoadLight: ADCON0=%10011100 : Pause 10 ADCIN Ldr,Ambient : Pause 10 DEBUG "AMBIENT=",DEC AMBIENT,10 While Setswitch=1 : Pause 330 : wend Return
___________________
WHY things get boring when they work just fine?
Also tried the following as well: (Still no luck)
Code:LoadTime: ANSEL=%00000010 ADCON0=%10000100 : Pause 10 ADCIN Poten,Time : Pause 10 ; Time=(Time/4) DEBUG "TIME=",DEC Time,10 Return LoadLight: ANSEL=%10000000 ADCON0=%10011100 : Pause 10 ADCIN Ldr,Ambient : Pause 10 DEBUG "AMBIENT=",DEC AMBIENT,10 While Setswitch=1 : Pause 330 : wend Return
___________________
Code:GOTO #2BTW ... Which version of PBP are you using ??? , < 3 ???WHICH kind of parameter
I am really sorry, I am not getting it yet what you are trying to say. I have read about 3 parameters, ANSEL, ADCON0 & 1. I have tried with different ways but
I am using PBP version 2.5.
___________________
IF you had upgraded to V 3.0 ...
your code had worked fine !!! ( It's written in the holy manual !!! ... I just discovered it at this time ...)
The error is in your channel selection parameter ...
Hi, Ok, I upgraded the whole PBP to 3 version. I even upgraded my MPLAB to Version 8.84 I am getting the following error:
Executing: "C:\PBP3\pbpx.exe" -ampasmwin -oq -z -p16F676 "Light_676.BAS"
PICBASIC PRO(TM) Compiler 3.0.5.4, (c) 1998, 2012 microEngineering Labs, Inc.
All Rights Reserved.
ERROR: Bad command parameter. -z
BUILD FAILED: Thu May 31 10:18:03 2012
___________________
Alain, here is the update. Updating to PBP3 didn't worked using MPLAB. But I copied the code to MicroCodeStudio. Compiled it and it compiled fine using PBP3 compiler. The result is the same:
They both (Time & Ambient) are outputting as '0' on my screen. Seems the problem is something else.Code:;-----------------PIC16F676--------------------------- Include "modedefs.bas" DEFINE OSC 4 ' OSCCON defaults to 4MHz on reset DEFINE ADC_BITS 10 DEFINE ADC_CLOCK 3 DEFINE ADC_SAMPLEUS 50 ;-------------CONFIGURATION FUSES SET HERE------------------------- @ __Config _XT_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _BODEN & _CP & _CPD '---------------------------------------- DEFINE DEBUG_REG PORTC DEFINE DEBUG_BIT 5 DEFINE DEBUG_BAUD 2400 DEFINE DEBUG_MODE 0 '-------Analog Input-------------- Poten Var PortA.1 Ldr Var PortC.3 '-------------------------------------- Time Var Word Time1 Var Word Counter Var Byte Ambient Var Word ;------REGISTERS SET -------- PORTA=0 PORTC=0 TRISA = %000010 TRISC = %001110 OPTION_REG = 128 PORTA=0 PORTC=0 CMCON=7 ANSEL=%10000010 ADCON1=%00110000 ADCON0=%10000000 '--------------------------------------- GoSub LoadTime Time1=Time GoSub LoadLight Counter=0 Main: ; my code here Goto Main LoadTime: ADCIN Poten,Time : Pause 10 DEBUG "TIME=",DEC Time,10 Return LoadLight: ADCIN Ldr,Ambient : Pause 10 DEBUG "AMBIENT=",DEC AMBIENT,10 Return
Both Time & Ambient pins are currently held high (5v)using 4.7k.
___________________
