USBout problem
Results 1 to 5 of 5
Thread: USBout problem
    Default Re: USBout problem
    USB "Frames" occur at 1ms intervals.
    When you send 50, it will have to wait until the next Frame to send 60.
    During that time any USBOUT statements will fail, and jump to the specified Label.
    Since you only have 1 Label, it always goes back to sending 50. 60 never gets sent.
    Using a label for each transmission will help.
    ' Main Program Loop
    Loop1:
        USBService        ' Must service USB regularly
        Buffer(0)=50
        USBOut 3, Buffer, Cnt, loop1
    Loop2:
        USBService
        Buffer(0)=60
        USBOut 3, Buffer, Cnt, loop2
    goto loop1
    May 2012
    Thanks DT, I'll try this code. BTW, does 1ms time interval mean that we can only send 1000 Bytes of data in a second via USB?
    Each Frame can transfer 64 bytes in Full Speed mode.
    So theoretically the transfer rate is 64000 bytes/sec.
    However, that rate is not acheivable without using ping-pong buffers, which PBP does not support.
    Without ping-pongs, I've measured approximately 56kBytes/sec.
    Other devices on the USB bus can reduce that as they use frames for their traffic too.
    May 2012
    Thanks a lot for the useful information.
