I'm using the following code to send data over USB which I learned from this thread: http://www.picbasic.co.uk/forum/showthread.php?t=5806
I check the received data on HyperTerminal but it only shows getting "2"s which means that Buffer[0] is always 50 and never takes the value 60. Could you help me with this problem please, what's the problem in my code? It's supposed to send 50 and 60 in an alternating pattern which correspond to "2" and "<" according to ASCII table.Code:DEFINE OSC 48 Buffer VAR BYTE[1] Cnt VAR BYTE counter VAR WORD ADCON1 = 15 ' Set all I/Os to Digital CMCON = 7 ' Disable Comparators Cnt = 1 USBInit ' Initialize USART ' Main Program Loop Loop: USBService ' Must service USB regularly Buffer(0)=50 USBOut 3, Buffer, Cnt, loop Buffer(0)=60 USBOut 3, Buffer, Cnt, loop goto loop end
