74hc595 help?
Results 1 to 4 of 4
Thread: 74hc595 help?
    Oct 2011
    Default 74hc595 help?
    HI FOR ALL...I WANT TO USE 74HC595 AND PIC16F628A TO SHOW NUMBER ON TOW 7 SEGMENT ...CAN ANY ONE HELP ME TO WRITE THE CODE TO SEND DATA BY 74HC595 TO 7 SEGMENT...THANKS FOR ALL...
    Default Re: 74hc595 help?
    The search box finds many, many results. One of which is here: http://www.picbasic.co.uk/forum/cont...gment-Displays
    http://www.scalerobotics.com
    In fact, I have same question, and either I'm not searching correctly, or all code returned is too complicated, has many side functions, so it is hard to "cut out" necessary part of the code.
    Aug 2003
    This is for a non-latching shift register which is fast enough for an LED display,
    but for latching shift register like 74595 you only have to pull the latch pin at the end right before the return.
    byte cnt’
    byte buff’
    byte send byte’ byte to send to port
    shiftbyte:
    for cnt = 0 TO 7
    buff = sendbyte >> cnt;
    SERCLK_PIN = 0;
    SERDAT_PIN = buff.bit0;
    SERCLK_PIN = 1;
    NEXT cnt
