Hi , yes i do see where your going , with the shift statement and then getting only the nibbles1 and 3 that are changed and store those for reference , but all 4 nibbles change as per attached sheet , the only thing that ties them consistently is the OBC code reference.
so a generate formula using the OBC Ref is the answer or else i store each 2 bytes per code.
