help calculating word hex code from OBC value of IR signal
Results 1 to 9 of 9
    Feb 2012
    PERTH AUSTRALIA
    Default help calculating word hex code from OBC value of IR signal
    Hi guys ,
    i need help to be able to store the OBC value of the IR code and generate via formula the word value in hex it represents from it to send.
    reason is that the obc value is able to be stored as a 1 byte ( FF) and the represented hex is of OBC ( FF FF ) saves a lot of stored space and i can generate a value for OBC when knowing what key it represents and then the next without using a table on all occasions for sequencing of IR codes
    I know that it seems to be a compliment value of but NOT CLEAR how it comes about and how i may calculate it from stored OBC value
    eg OBC 0 = 00 FF ( 0000 0000 1111 1111)
    OBC1 = 80 7F ( 1000 0000 0111 1111) ( + 80 - 40) when looking at each byte
    OBC2 = 40 BF ( 0100 0000 1011 1111) ( - 40 + 40)
    OBC3 = C0 3F ( 1011 0000 0100 1111) ( +80 - 80)
    OBC4 = 20 DF ( 0010 0000 1101 1111) ( -A0 + A0)
    obc5 = A0 5F ( 1010 0000 0101 1111) ( +80 - 80)
    any help pointing me how i can do this would be great
    Cheers
    Sheldon
    Dec 2010
    Default Re: help calculating word hex code from OBC value of IR signal
    I know nothing about the code - only what I see from your example, so this reply might be totally bogus.
    In the example, the lowest nibble is always F and the third nibble is always 0. If this is always true, you can simply use shift to strip them off and put them back. In the first case (OBC1), shift 7F >> 4, to get 7. Then add it to 80, and store 87. To recover, use logical AND to recover the low nibble. Subtract that from the stored value to get the high byte, then shift it << 4 and add F to get the low byte back.
    Feb 2012
    PERTH AUSTRALIA
    unforntuanty is not that simple a from this example
    OBC92 = 3A C5
    OBC93 = BA 45
    OBC65 = 82 7D
    OBC64 = 02 FD
    a lot of the codes follow x2 xD at point but then change to xA x5 etc and not what seems the same point offset of 16 OBC values
    Feb 2012
    PERTH AUSTRALIA
    looking again at your example , how would a shift be done in the basic code , i have included a summery sheet of the codes for ref , it seem each OBC 0 - 15 . 16 - 31, etc code x0 xF changes on each 16 OBC codes group
    since each OBC code is different for each remote using the same function , yes i have to allow for 3 remotes that look similar , do the same function over all , but are sending different codes for the same function , i thought that having only the OBC for each remote key would save a lot of storage space on the prom.
    NEC1 - IR Remote Code table Reference
    SigKey # Button key FUNCTION Reference Red to White
    16 or 20 steps
    Remote 1
    Remote 2
    Remote 3
    OBC HEX Full Hex Code OBC HEX Full Hex Code OBC HEX Full Hex Code
    1 Brightness UP 5 5F 00 FF A0 5F 0 FF 00 F7 00 FF 92 C5 00 FF 3A C5
    2 Brightness DWN 4 DF 00 FF 20 DF 1 7F 00 F7 80 7F 93 45 00 FF BA 45
    3 PWR Off 6 9F 00 FF 60 9F 2 BF 00 F7 40 BF 65 7D 00 FF 82 7D
    4 PWR On 7 1F 00 FF E0 1F 3 3F 00 F7 C0 3F 64 FD 00 FF 02 FD
    5 RED 1 9 6F 00 FF 90 6F 4 DF 00 F7 20 DF 88 E5 00 FF 1A E5
    6 GREEN 6 8 EF 00 FF 10 EF 5 5F 00 F7 A0 5F 89 65 00 FF 9A 65
    7 BLUE 11 10 AF 00 FF 50 AF 6 9F 00 F7 60 9F 69 5D 00 FF A2 5D
    8 WHITE 16 (20) 11 2F 00 FF D0 2F 7 1F 00 F7 E0 1F 68 DD 00 FF 22 DD
    9 Button 1 2 13 4F 00 FF B0 4F 8 EF 00 F7 10 EF 84 D5 00 FF 2A D5
    10 Button 2 7 12 CF 00 FF 30 CF 9 6F 00 F7 90 6F 85 55 00 FF AA 55
    11 Button 3 12 14 8F 00 FF 70 8F 10 AF 00 F7 50 AF 73 6D 00 FF 92 6D
    12 Button 4 Flash(19) 15 0F 00 FF F0 0F 11 2F 00 F7 D0 2F 72 ED 00 FF 12 ED
    13 Button 5 3 21 57 00 FF A8 57 12 CF 00 F7 30 CF 80 F5 00 FF 0A F5
    14 Button 6 8 20 D7 00 FF 28 D7 13 4F 00 F7 B0 4F 81 75 00 FF 8A 75
    15 Button 7 13 22 97 00 FF 68 97 14 8F 00 F7 70 8F 77 4D 00 FF B2 4D
    16 Button 8 Strobe
    (18)
    23 17 00 FF E8 17 15 0F 00 F7 F0 0F 76 CD 00 FF 32 CD
    17 Button 9 4 25 67 00 FF 98 67 16 F7 00 F7 08 F7 28 C7 00 FF 38 C7
    18 Button 10 9 24 E7 00 FF 18 E7 17 77 00 F7 88 77 29 47 00 FF B8 47
    19 Button 11 14 26 A7 00 FF 58 A7 18 B7 00 F7 48 B7 30 87 00 FF 78 87
    20 Button 12 Fade (17) 27 27 00 FF D8 27 19 37 00 F7 C8 37 31 07 00 FF F8 07
    21 Button 13 5 17 77 00 FF 88 77 20 D7 00 F7 28 D7 24 E7 00 FF 18 E7
    22 Button 14 10 16 F7 00 FF 08 F7 21 57 00 F7 A8 57 25 67 00 FF 98 67
    23 Button 15 15 18 B7 00 FF 48 B7 22 97 00 F7 68 97 26 A7 00 FF 58 A7
    24 Button 16 Smooth (16) 19 37 00 FF C8 37 23 17 00 F7 E8 17 27 27 00 FF D8 27
    25 Button 17 Red Up 20 D7 00 FF 28 D7
    26 Button 18 Green Up 21 57 00 FF A8 57
    27 Button 19 Blue up 22 97 00 FF 68 97
    28 Button 20 Quick 23 17 00 FF E8 17
    29 Button 21 Red Dwn 16 F7 00 FF 08 F7
    30 Button 22 Green Dwn 17 77 00 FF 88 77
    31 Button 23 Blue Dwn 18 B7 00 FF 48 B7
    32 Button 24 Slow 19 37 00 FF C8 37
    33 Button 25 DIY1 12 CF 00 FF 30 CF
    34 Button 26 DIY2 13 4F 00 FF B0 4F
    35 Button 27 DIY3 14 8F 00 FF 70 8F
    36 Button 28 Auto 15 0F 00 FF F0 0F
    37 Button 29 DIY4 8 EF 00 FF 10 EF
    38 Button 30 DIY5 9 6F 00 FF 90 6F
    39 Button 31 DIY6 10 AF 00 FF 50 AF
    40 Button 32 Flash 11 2F 00 FF D0 2F
    41 Button 33 Jump 3 4 DF 00 FF 20 DF
    42 Button 34 Jump 7 5 5F 00 FF A0 5F
    43 Button 35 Fade3 6 9F 00 FF 60 9F
    44 Button 36 Fade7 7 1F 00 FF E0 1F
    Feb 2012
    PERTH AUSTRALIA
    Hi , yes i do see where your going , with the shift statement and then getting only the nibbles1 and 3 that are changed and store those for reference , but all 4 nibbles change as per attached sheet , the only thing that ties them consistently is the OBC code reference.
    so a generate formula using the OBC Ref is the answer or else i store each 2 bytes per code.
    Feb 2012
    PERTH AUSTRALIA
    some time the obvious is hard to grasp but if you look at the table and you take the last byte of each code and inverse it , it is the value for the 3rd byte or visa vera if you inverse 3rd byte u get 4byte
    eg full hex code 00 FF 20 DF = OBC 4
    Ok 00 FF are the device code and i just need to know these for each remote type
    20 is the inverse of DF , which is referred to as OBC 4 , why i am not sure perhaps becuase it the 4th change from FF when taking $40 from FF
    if i store the value of DF for this key and do bitwise not ( inverse) on this value the result will be 20 byte 3
    The following code does this
    Byte4 = $DF
    Byte3 = (~ byte4)
    more fun ahead
    Feb 2012
    PERTH AUSTRALIA
    for those wondering how the OBC in a IR code comes about here is how it works
    OBC value
    is based on the 3rd byte then if
    obc0 = 00
    obc1 = 80
    obc2 = 40
    obc3 = c0
    obc4 = 20
    obc5 = A0
    The bit order is reversed.
    OBC0 = 00h 00000000b reversed = 00000000b 00h
    OBC1 = 01h 00000001b reversed = 10000000b 80h
    OBC2 = 02h 00000010b reversed = 01000000b 40h
    OBC5 = 05h 00000101b reversed = 10100000b A0h
    OBC32 = 20h 00100000b reversed = 00000100b 04h
    etc.
    regards
    Bombay, India
    First of all, I don't know what is OBC. Please expand abbreviations the first time around.
    Taking just these 2 examples, it seems pretty intuitive to me.
    Let us take the case of Sigkey#34 button 26. The code you see is 00 FF B0 4F
    The first byte 00 must be some kind of device ID or something.
    The second byte is just the binary inverse (NOT operation) of the first byte
    The third byte is the function code
    and the 4th byte is the inverted function code. Just like the second byte.
    The easiest way to do this is to have a lookup table having the codes for bytes 1 and 3 and you generate the bytes 2 and 4 before sending them out.
    It's that easy
    Feb 2012
    PERTH AUSTRALIA
    yes as i worked through it i found i only needed to store 1 byte , for BUTTON code and 1 byte for the remote type ( DEVICE ) ,
