Array and ASCII
Results 1 to 19 of 19
Thread: Array and ASCII
    May 2006
    Del Rio, TX, USA
    Default Re: Array and ASCII
    Quote Originally Posted by Seahound1 View Post
    There is very little in terms of documentation (remzibi 3DR)....but there is a GPS simulator (happykillmore.com) incorporated into the config software which generates standard NMEA GPS sentences, for example
    $GPGGA,000000,4124.8963,N,08151.6838,W,1,05,1.5,28 0.2,M,-34.0,M,,,*59
    $GPRMC,000000,A,4916.45,N,12311.12,W,000.5,253.7,191194,020.3,E*68
    Looking it over quickly, this is the value you are looking for, and likely what the remzibi 3DR calls "heading". (It would actually be true course if provided by a GPS). The important issue is the format. It looks like a string 5 characters long is required.
    So let's say you have a WORD variable MyHeading that contains a value between 0-359. To output this as it appears in the NMEA sentence use:
    SEROUT bob, baud, [DEC3 MyHeading , ".0"]
    You can see I added the decimal point and zero to fill out the five characters.
    HTH
    Sep 2011
    Yes you are right.....sorry I maybe didn't make it very clear. The protocol for the OSD is that it must see the other characters in the array (as per below) for it even to respond. According to the firmware notes is must see the preample ($GPRMC for example) from this I guess it gets how many commas to expect so that it knows it has the whole NMEA sentence. That is why I was forced to use the array in the first place. For example I just tried SEROUT2 ("$GPRMC, 00000, etc, etc,")..... is says it has a GPS connection but then stops. Using the array it confirms GPS connection and then goes on to dispay the OSD. So I thought I could fool it into showing the heading using the two methods below....but OH NO...Is there a way to send the first part of an array and then the remainder......if I could that at least I could try using the normal method you mention below.
    May 2006
    Del Rio, TX, USA
    How about this:
    RMC_array[48]=","
    RMC_array[49]= Heading DIG 2 + "0"
    RMC_array[50]= Heading DIG 1 + "0"
    RMC_array[51]= Heading DIG 0 + "0"
    RMC_array[52]= "."
    RMC_array[53]= "0"
    RMC_array[54]=","
    Sep 2011
    Let me give it a whirl and see.....
    Just tried it and it doesn't work...but great idea though...thanks
    Sep 2011
    I tried to use other modifiers as well...but then saw they can only be used in the send statement ...Serout2 ( #heading) which converts the heading into a set of ASCII characters. Tried this combination too
    WPT_array[47]=Dec_off Dig 0+"0"
    WPT_array[48]=","
    WPT_array[49]= #course1
    WPT_array[50]= Hex2 course2
    WPT_array[51]= Hex course3
    WPT_array[52]="."
    But it won't compile....
    May 2006
    Del Rio, TX, USA
    Have you tried to send some test strings? something like:
    SEROUT2 bob, baud, ["$GPRMC,220516,A,5133.82,N,00042.24,W,173.8,231.8,1 30694,004.2,W*70"]
    If that works, try this (assuming Heading is the variable that contians your heading data):
    SEROUT2 bob, baud, ["$GPRMC,220516,A,5133.82,N,00042.24,W,173.8,",DEC3 Heading,".0,130694,004.2,W*70"]
    Sep 2011
    Tried that too....just testin to see if I can split the Array....send upto 48 then insert dec3 heading and then send the remainder of the string....see if that works....worth a try....starting to bang my head against the wall here :>)
    Serout2 bob, baud, [Str WPT_array\48,dec3 heading, Str WPT_array_2\13,13,10] just tried this as well and that doesn't work....oh well
