Since you are doing 50, one of these might help: http://www.ebay.com/sch/i.html?_nkw=...knockout+punch
Not terribly cheap, but all you do is drill a round hole and you get a perfect square.
Hi Lerameur!
The solution ready depends upon how your box is configured. If the circuit board or electronics are mounted on a/the flat lid then you could use a "nibbler" to create a square "slot" in the edge of the box. There is also a 90 degree punch (#81652 or #82394) from Micromark (www.micromark.com). Best, Ed
A 5 pin miniDIN connector would fit the bill pretty well. Only a $1.08 from mosuer. Here is a data sheet link:
http://www.mouser.com/catalog/specsheets/KC-300168.pdf
Tim Barr
HI,
the 5 pin mini din is still a square.. but I really like that square punch from Ramius, It seems to be similar to a mortiser bit but is good for plastic, thanks
ken
Maybe something like this
http://parts.digikey.com/1/parts/103606-conn-audio-jack-3-5mm-4cond-smd-sj-43514-smt.html
