More help on LOOKUP tables please.
Results 1 to 11 of 11
    Jul 2009
    Worcester South Africa
    Default Re: More help on LOOKUP tables please.
    There is a push button on portc.3, then depending on how many times its pressed, ( up to 8 times ) the program must then jump to that number's sub routine. I hope that make sense.
    so ...
    a "basic" set of IF ... THEN ... GOTO is the trick.
    SELECT CASE is the smart way to write it ... but is it available with v 2.32 ???
    LOOKUPx is generally used to retrieve constants/values/strings from a table , not label adresses.
    Jul 2009
    Yes, IF......THEN's is what I'll have to do , thought I could get away without them.
    Thanks a lot for all the help.
