More help on LOOKUP tables please.
Results 1 to 11 of 11
    Jul 2009
    Worcester South Africa
    Default Re: More help on LOOKUP tables please.
    This ON GOTO command, does it work with PBP 2.32 ?? here is part of the code;
    COUNT PORTC.3, 15000, c1 'put pulses in C1
    ON c1 GOTO S1,S2,S3,S4,S5,S6,S7,S8 I get a syntax error on this line, do I miss something? S1 to S8 is labels, C1 is defined as a variable.
    Thanks.
    does it work with PBP 2.32 ???
    Wowwww !!!
    PBP2.32 might be @ least 10 years old ... more than time to upgrade !
    my 2.50 version manual does not show ON GOxxx commands ( appears in the v2.60 manual ), sooo ... prepare your
    Jul 2009
    Aag ja that explains it.
    thanks for the help and the quick response, nice to have willing clever people on line.
    will just have to make a plan now.
    Hi, Surfies
    Could have been much easier for us YOU to explain what you physically tried to do ...
    I smell some kind of overkill trick here
    Jul 2009
    There is a push button on portc.3, then depending on how many times its pressed, ( up to 8 times ) the program must then jump to that number's sub routine. I hope that make sense.
    so ...
    a "basic" set of IF ... THEN ... GOTO is the trick.
    SELECT CASE is the smart way to write it ... but is it available with v 2.32 ???
    LOOKUPx is generally used to retrieve constants/values/strings from a table , not label adresses.
    Jul 2009
    Yes, IF......THEN's is what I'll have to do , thought I could get away without them.
    Thanks a lot for all the help.
