More help on LOOKUP tables please.
Results 1 to 11 of 11
    May 2006
    Del Rio, TX, USA
    Default Re: More help on LOOKUP tables please.
    Do what Darrel says.
    However, if you need to intermix things in a LOOKUP table, then here is a method to achieve that:
    lbl_1stPlace CON $FF
    lbl_2ndPlace CON $FE
    lbl_3rdPlace CON $FD
    lbl_4thPlace CON $FC
    My_Index_Var VAR WORD
    MY_LOOKUP_Var VAR WORD
    LOOKUP My_Index_Var, [1,2, lbl_1stPlace,3,4, lbl_2ndPlace ,5,6, lbl_3rdPlace,7,8, lbl_4thPlace,9,10], MY_LOOKUP_Var
    SELECT CASE MY_LOOKUP_Var
     CASE lbl_1stPlace GOTO 1stPlace
     CASE lbl_2ndPlace GOTO 2ndPlace
     CASE lbl_3rdPlace GOTO 3rdPlace
     CASE lbl_4thPlace GOTO 4thPlace
    END SELECT
    1stPlace:
    2ndPlace:
    3rdPlace:
    4thPlace:
    Jul 2009
    Worcester South Africa
    Thanks Darrel and SteveB will try that and let you know.
    Jul 2009
    This ON GOTO command, does it work with PBP 2.32 ?? here is part of the code;
    COUNT PORTC.3, 15000, c1 'put pulses in C1
    ON c1 GOTO S1,S2,S3,S4,S5,S6,S7,S8 I get a syntax error on this line, do I miss something? S1 to S8 is labels, C1 is defined as a variable.
    Thanks.
    does it work with PBP 2.32 ???
    Wowwww !!!
    PBP2.32 might be @ least 10 years old ... more than time to upgrade !
    my 2.50 version manual does not show ON GOxxx commands ( appears in the v2.60 manual ), sooo ... prepare your
    Jul 2009
    Aag ja that explains it.
    thanks for the help and the quick response, nice to have willing clever people on line.
    will just have to make a plan now.
    Hi, Surfies
    Could have been much easier for us YOU to explain what you physically tried to do ...
    I smell some kind of overkill trick here
    Jul 2009
    There is a push button on portc.3, then depending on how many times its pressed, ( up to 8 times ) the program must then jump to that number's sub routine. I hope that make sense.
