Servos and Plusin math
Results 1 to 4 of 4
    Mar 2011
    Los Angeles, California
    Default Servos and Plusin math
    Hi All!
    Okay so I know that the pulse width for a servo is from 1 ms to 2 ms with 1.5 ms as neutral. I used Plusin PORTA.0,1,Rawpulse. The variable Rawpulse should display the pulse width to the servo. What I do not understand is why does neutral on the RC transmitter give a Rawpulse result of 380? Thanks, Ed
    Default Re: Servos and Plusin math
    It depends on the clock speed. It's in the manual....
    EN82fn
    Mar 2011
    Okay, then in the manual the results are given in us units (micro-seconds) which is 1000 time more than in ms (milliseconds). IE "If a 4MHz oscillator is used, the pulse width is returned in 10us increments. If a 20MHz oscillator is used, the pulse width will have a 2us resolution." I am using a 10MHz crystal. Best, Ed
    So, with a 10MHz crystal the pulswidth is returned in units of 4us, a result of 380 equals a pulsewidth of 1520us.
