Calculatorīs LCD
Results 1 to 8 of 8
    do you have any part# for your LCD or datasheet. That will be helpful in case you really need help by someone here
    Sao Paulo - Brazil
    Question No embeded controller LCD
    Hi Steve,
    youīre right about the Part#
    The problem is : I have a big box full of those 8 digits calculatorīs LCD (aprox 2000 units) with no Idīs, but I know they were origanlly designed for calculators.
    I did some comparisons with some other chinese calculators and the display pinout are practically the same, with some no relevant changes (pin spacing etc)
    What I would like to know is the main idea on how to drive a regular LCD with no embeded controller and if it is possible to be done with PicBasic.
    Sérgio
    Regular LCD must have a regular frequency running on the backplane pin. HPWM can be used for that. Once you have a frequency on this pin, just try to find the according pinout.
    Basically it's not really different than to drive regular multiplexed 7 segment display
    and yes you can handle it under PBP, but it's maybe easier to use LCD driver IC for that depending on your programming skills.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
