for/loop for a timer?
Results 1 to 4 of 4
    Scott's Avatar
    Scott Guest
    Angry for/loop for a timer?
    Is it possible to use a for loop to create a timer in software? It does not need to be very accurate. I cannot use timer0, timer1 or timer2 for I am already using them for user interface. See below of an example of what I am trying to achieve. It works but why will it not work correctly?
    rx:
    for i = 0 to 60000
    timer = timer + i
    pause 1
    next i
    if (timer == 60000)then
    trigger = trigger + 1
    timer = 0
    if (trigger == 1)then
    trigger = 0
    goto a2d
    goto rx
    I am using a PIC16F876A @ 20Mhz. I know the instruction cycle is around 200ns and the pause is for 1ms. It takes 1000ms to equal 1sec thus 60000.
    Thanks in advance,
    Scott
    What are you trying to achieve?... doing an AD conversion once per minute, otherwise keeping time in 1mS Steps?
    CounterA var word
    Loop:
    For CounterA=0 to 60000
    Pause 1
    Next CounterA
    Gosub A2D
    Goto Loop
    Scott's Avatar
    Scott Guest
    I am sending data out over the GPRS network to a webserver. One minute is the minimum for the timer! I would like to be able to increment trigger every time my loop reaches 60000 with trigger = trigger + 1. My thought is that I can set "if (trigger == X)" trigger with X = 1, 2 and so on... depending on the cellular sevice provided or customers request.
    Dec 2003
    Wichita KS
    Hello Scott,
    Scott>>I am sending data out over the GPRS network to a webserver. One minute is the minimum for the timer! I would like to be able to increment trigger every time my loop reaches 60000 with trigger = trigger + 1. My thought is that I can set "if (trigger == X)" trigger with X = 1, 2 and so on... depending on the cellular sevice provided or customers request.<<
    Use Melanies Code, Unless you *must* use a interupt. Melanies code will give you 1 minute delay, it is much shorter.
    Or you can use a another kind of loop:
    Loop:
    Pause 60000
    Gosub A2D
    Goto Loop
    If you use a interupt, this is a poor way how to do it. PBP will not call the interupt until the Pause is over with. Unless you use a assembly interupt.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 17:39
  2. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 16:45
  3. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 07:56
  4. Timer interrupt frequency
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 17th January 2009, 23:49
  5. timer interupt help 16f73
    By EDWARD in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2005, 08:41
