SHIFTOUT syntax not understood - can't send any variables contents, while text is ok
Results 1 to 5 of 5
    Default Re: SHIFTOUT syntax not understood - can't send any variables contents, while text is
    SHIFTOUT sends the content of the variable in "binary" format, not as ASCII text - which I believe is what the display is expecting. It's like sending a variable using HSEROUT where you use the DEC-modifer to send the content of a variable as text instead of as a "raw number".
    Unfortunately SHIFTOUT does not (AFAIK) support any modifiers (DEC, HEX etc) so you need to do it manually. This compile but I can not test it.
    temp = CNT_A / 1000
    GOSUB SendIt
    CNT_A = CNT_A - (temp * 1000)
    temp = CNT_A / 100
    GOSUB SendIt
    CNT_A = CNT_A - (temp * 100)
    temp = CNT_A / 10
    GOSUB SendIt
    temp = CNT_A - (temp * 10)
    GOSUB SendIt
    SendIt:
      SHIFTOUT SDO, SCK, MODE, [temp + 48]
    SWITZERLAND (french speaking)
    Thanks a lot Henrik.
    Your code works effectively
    I'm not used to use the SHIFTOUT command so I got to learn how it works.
    Thank you.
    Roger
