Try something like
If that does not work post exactly what the display is displaying.Code:MyVar = $30+Cnt_A shiftout sdo,SCK,mode,[MyVar]
Try something like
Unfortunately it doesn't work.
I see characters, displayed one by one, just if it would be the display's internal character set that is listed. But it is not exactly following the character's set order; some characters follow correctly the table and then it jumps to some further characters and so on.
Every displayed character appears on the first position of the display which is correct according to the "set cursor home" command.
My LCD is a EA DOGM081x-A and ST7036 controlled.
Roger
SHIFTOUT sends the content of the variable in "binary" format, not as ASCII text - which I believe is what the display is expecting. It's like sending a variable using HSEROUT where you use the DEC-modifer to send the content of a variable as text instead of as a "raw number".
Unfortunately SHIFTOUT does not (AFAIK) support any modifiers (DEC, HEX etc) so you need to do it manually. This compile but I can not test it./Henrik.Code:temp = CNT_A / 1000 GOSUB SendIt CNT_A = CNT_A - (temp * 1000) temp = CNT_A / 100 GOSUB SendIt CNT_A = CNT_A - (temp * 100) temp = CNT_A / 10 GOSUB SendIt temp = CNT_A - (temp * 10) GOSUB SendIt END SendIt: SHIFTOUT SDO, SCK, MODE, [temp + 48] RETURN
Thanks a lot Henrik.
Your code works effectively
I'm not used to use the SHIFTOUT command so I got to learn how it works.
Thank you.
Roger
