SHIFTOUT syntax not understood - can't send any variables contents, while text is ok
Results 1 to 5 of 5
    SWITZERLAND (french speaking)
    Default SHIFTOUT syntax not understood - can't send any variables contents, while text is ok
    Hello,
    I'm trying to send the content of a variable to a SPI LCD.
    As long as I send "text", it works; the LCD shows "text".
    When I try to send the content of a variable, i.e. a counter, the display goes crazy and shows sort of random characters.
    Any idea what I'm doing wrong or missing?
    ' PIC 16F690 Fuses (MPASM)
       @ __config _FCMEN_OFF &_IESO_OFF &_CPD_OFF &_WDT_OFF &_INTRC_OSC_NOCLKOUT &_BOR_OFF &_CP_OFF &_PWRTE_OFF &_MCLRE_OFF
    ' Registers   76543210
       OPTION_REG = %10000000 'PORT A&B Pull-Ups disabled (look WPUA & WPUB)
       OSCCON     = %01110000 'Internal RC set to 8Mhz
       ANSEL      = %00000000 'Disable analog inputs Channels 0 to 7
       ANSELH     = %00000000 'Disable analog inputs Channels 8 to 11
       WPUB       = %00000000 'Disable weak pull-ups
       ADCON0     = %00000000 'A/D Module is OFF
       CM1CON0    = %00000000 'Comparator1 Module is OFF
       CM2CON0    = %00000000 'Comparator2 Module is OFF
       INTCON     = %00000000 'INTerrupts CONtrol
       TRISA      = %00000000 'Set Input/Output (0 to 5)
       PORTA      = %00000000 'Ports High/Low (0 to 5)
       TRISB      = %00000000 'Set Input/Output (4 to 7)
       PORTB      = %00000000 'Ports High/Low (4 to 7)
       TRISC      = %00000000 'Set Input/Output (0 to 7)
       PORTC      = %00000000 'Ports High/Low (0 to 7)
    ' Defines
       define OSC 8
    ' Variables
       RS    var PORTB.5 'instruction or command =0, data =1
       SCK   var PORTB.6 'Clock pin
       SDO   var PORTB.4 'Data Out pin (SI on display's side)
       Reset var PORTB.7 'LCD's reset pin - could be connected to VDD (+VDC)
       CSB   var PORTC.7 'LOW active pin - could be connected to VSS (GND)
       Mode  con 1       'MSBFIRST - Clock idles low
       RS_t  con 1       'Set PAUSE time for RS transition
       Cnt_A var byte    'just a counter variable
       cnt_a = 0
    INIT:
    '  "EA-DOGM162L-A" LCD display specific settings
       pause 40     'wait for LCD to startup
       high reset  : pause 1
       low RS      : pauseus RS_t
       shiftout sdo,SCK,mode,[%00111001] : pauseus 20 'Function Set/Instr. table 1
       shiftout sdo,SCK,mode,[%00011100] : pauseus 20 'Bias set
       shiftout sdo,SCK,mode,[%01010010] : pauseus 20 'Power control + Contrast (HiByte)
       shiftout sdo,SCK,mode,[%01101001] : pauseus 20 'Follower control
       shiftout sdo,SCK,mode,[%01110111] : pauseus 20 'Contrast (LowByte)
       shiftout sdo,SCK,mode,[%00001100] : pauseus 20 'Display ON
    MAIN:
      low rs : pauseus RS_t             'set COMMAND mode
      shiftout sdo,SCK,mode,[%00000010] : pause 1   'set cursor home
      high RS : pauseus RS_t            'set DATA mode
      shiftout sdo,SCK,mode,["test"]
      shiftout sdo,SCK,mode,[Cnt_A]
      cnt_a = cnt_a + 1
      goto main:
    Thank you
    Roger
    NB: most of the time, the "%" in my posts are replaced by some "double-square" symbol; how to I avoid this?
    Roger
    Default Re: SHIFTOUT syntax not understood - can't send any variables contents, while text is
    Try something like
    MyVar = $30+Cnt_A
    shiftout sdo,SCK,mode,[MyVar]
    If that does not work post exactly what the display is displaying.
    Unfortunately it doesn't work.
    I see characters, displayed one by one, just if it would be the display's internal character set that is listed. But it is not exactly following the character's set order; some characters follow correctly the table and then it jumps to some further characters and so on.
    Every displayed character appears on the first position of the display which is correct according to the "set cursor home" command.
    My LCD is a EA DOGM081x-A and ST7036 controlled.
    Roger
    SHIFTOUT sends the content of the variable in "binary" format, not as ASCII text - which I believe is what the display is expecting. It's like sending a variable using HSEROUT where you use the DEC-modifer to send the content of a variable as text instead of as a "raw number".
    Unfortunately SHIFTOUT does not (AFAIK) support any modifiers (DEC, HEX etc) so you need to do it manually. This compile but I can not test it.
    temp = CNT_A / 1000
    GOSUB SendIt
    CNT_A = CNT_A - (temp * 1000)
    temp = CNT_A / 100
    GOSUB SendIt
    CNT_A = CNT_A - (temp * 100)
    temp = CNT_A / 10
    GOSUB SendIt
    temp = CNT_A - (temp * 10)
    GOSUB SendIt
    SendIt:
      SHIFTOUT SDO, SCK, MODE, [temp + 48]
    Thanks a lot Henrik.
    Your code works effectively
    I'm not used to use the SHIFTOUT command so I got to learn how it works.
    Thank you.
    Roger
