16f1824 MCLR pin going low causes PIC to reset - what am I missing?
Results 1 to 13 of 13
    Dec 2003
    Storrs, Ct.
    Default Re: 16f1824 MCLR pin going low causes PIC to reset - what am I missing?
    That pic is new to me but it looks like you may also need to check the configuration word 1 bit 6.
    "It will never happen here!" just happened here.
    My thoughts and prayers for Sandy Hook victims and families.
    Miami, Florida USA
    Are you using an external pullup resistor for your switch configuration?
    Anonymous
    Mar 2009
    no...if i'm reading the datasheet correctly, it is possible to use a weak pullup for that pin, which is what i've done...
    OPTION_REG.7 = 0
    WPUA =  %00011000
    IOCAN = %00011000
    Miami, Florida USA
    Quote Originally Posted by HankMcSpank View Post
    Hmmm, try using an external resistor (maybe 4.7K Ohms) and see if you have the same problem. You might be drawing too much current when closing the switch and that might be causing the problem.
    Anonymous
    Mar 2009
    just tried an external pullup resistor on RA3 (vs internal weak pullup)- same results.....if I ground RA3 (MCLR pin), the PIC resets
    ...aaaaaaarrrrgggHHHH
    Before programming your PIC, you've checked the configuration bits in your device programmer software and they match your code right?
    Are you sure your programmer do it right?
    Mar 2009
    If it helps, I'm using a Pickit2 programmer ...whilst I've been away from all of this for a while, I don't recall having to do anything special previously wrt the programmer when using RA3 as a digital input (albeit probably using a different chip).
    Just moved the Sitch off RA3...to another input pin, device is not resetting now whe the switch is pressed, so it is definitely related to when RA3 goes low, the 16f1824 is resetting!
