pulse counter
Results 1 to 7 of 7
Thread: pulse counter
    May 2012
    Wink pulse counter
    hi,i use pic16f628a.i used the code below.connected the circuit like the image.i used pin 12 for input.but lcd shows nothing.
    can sometell me what is the problem.
    thx.
    Default Re: pulse counter
    CMCON = 7 'turn off analog comparators which kill digital on port A
    TRISA =%00000000 'all porta as outputs
    TrisB.4=0
    TrisB.5=0 ' make portb4:5 outputs
    May 2012
    thank you archangel.
    i will test it and let you know the result.
    In addition to Archangel. From what I know of Isis/Proteus whatever it is called) you
    - don't need to add a voltage regulator but some power terminal and assign them to Vdd.
    - unless you modify the config fuses, you'll need to tie MCLR to Vdd,
    pretty much it
    Mar 2011
    Los Angeles, California
    Hi Daydream,
    I am not sure if your drawing is complete (showing all components) or just simplified and if it is complete then you are missing the filter / anti-oscilation capacitors at the output of the 7805. Typically, at least a 1 uf tantilum capacitor is necessary and it does not hurt to add a .1 uf and then some larger value (greater than 10 uf). If it helps, usually pin 4 (MCLR) is tied to +5v thru a 10k resistor as Mister_e pointed out. Best, Ed
    May 2012
    Wink Re: pulse counter
    hi,i added the capacitors and the 10 kohm resistor and lcd shows the frequecy.
    so thank you all for your help.
    could someone change the main loop so that lcd shows freq and Period on the first and second line.
    thx.
