Linear acceleration ramp
Results 1 to 14 of 14
    Dec 2010
    Default Re: Linear acceleration ramp
    Although you said linear, I assume you really can live with a staircase.
    If that's the case, and I understand the question correctly, then it's just simple math.
    Your example: ramp from 10 (x) to 560 (y) in 42 seconds (n).
    Suppose you want 1 step per second. In that case:
    stepsize = (y-x)/n
    output = x
    FOR QQ = 1 to n
    PAUSE 1000
    output = x + stepsize
    next QQ
    Replace the pause with a 1 second interrupt if you need to do other things.
    "output" feeds yout DAC
    Quote Originally Posted by Charlie View Post
    stepsize = (y-x)/n
    output = x
    FOR QQ = 1 to n
    PAUSE 1000
    next QQ
    I will try that, thanks!
    May 2006
    Del Rio, TX, USA
    On problem is the rounding error you will get with (y-x)/n
    In your example: (560-10)/42 = 13.09524
    But, PBP will only see 13. So, at the end of your routine, you will end up with 10 + (42*13) = 556
    You will need to put in one line at after Next QQ:
    Output = y
    May 2006
    Del Rio, TX, USA
    Here is another alternative: Vary the period you increment your speed.
    This examply uses PAUSE.
    Incr_Time_ms = (1000 * Duration) / (End_Val - Start_Val)
    Current_Val = Start_Val
    Do Until Current_Val = End_Val
       PAUSE Incr_Time_ms
       Current_Val = Current_Val + 1
    Loop
    What would be ideal is set up a timer and add a value so that it overflows after "Incr_Time_ms". You can then use interrupts, or just poll the flag bit. increment your "Current_Val", clear the flag bit, and then add the value to set up the overflow after "Incr_Time_ms". Wash-Rinse-Repeat until "Current_Val = End_Val"
    Quote Originally Posted by SteveB View Post
       PAUSE Incr_Time_ms
    Loop
    Hi Steve,
    I've used what you said, and I've also included a deceleration ramp:
    (sorry for renaming the values, it's for a easier integration in my main program).
    ' PIC18F4431 initialization
    DEFINE OSC 40
    DEFINE LCD_DREG PORTD
    DEFINE LCD_EREG PORTB
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_EBIT 6
    DEFINE LCD_RSBIT 7
    tacc var BYTE
    tdec var BYTE
    cacc var word
    cdec var word
    ref var word
    fmin var word
    freq var WORD
    tacc=1
    tdec=10
    fmin=10
    ref=1200
    PAUSE 4000
    LCDOUT $fe,$1
    cacc = (1000 * tacc) / (ref - fmin)
    cdec = (1000 * tdec) / (ref - fmin)
    lp:
       if freq<ref then PAUSE cacc
       if freq>ref then PAUSE cdec
       if freq<ref then freq = freq + 1
       if freq>ref then freq = freq - 1
       LCDOUT $fe,$2,DEC5 freq
       if PORTC.0=%1 then ref=500
    goto lp
    It works quite good, but I cannot exeed 65 seconds (because 66*1000=66000, 16-bit integer is overflowed).
    But, more importantly, I want to integrate the loop in a low priority DT interrupt. I really don't understand how you're using flags, etc. (I'm a beginner lol).
    May 2006
    Del Rio, TX, USA
    Here is a start (not tested!). But it should get you going in the right direction. I only included the acceleration stuff to keep the logic simpler.
    You will need the include files (Get Darrel's from http://darreltaylor.com/DT_INTS-18/downloads.html), and make sure the file names match.
    ' PIC18F4431 initializationDEFINE OSC 40
    DEFINE LCD_EBIT 6
    DEFINE LCD_RSBIT 7
    tacc var BYTE
    tdec var BYTE
    cacc var word
    cdec var word
    ref var word
    fmin var word
    freq var WORD
    cacc_div VAR BYTE
    cdec_div VAR BYTE
    tacc=1
    tdec=10
    fmin=10
    ref=1200
    PAUSE 4000
    LCDOUT $fe,$1
    INCLUDE "DT_INTS-18.bas"
    INCLUDE "ReEnterPBP-18.bas"
    INCLUDE "TimerControl.pbp"  ; Timer Control Routines
            INT_Handler   TMR1_INT,  _UpdateTickCount,   PBP,  yes
    @   INT_ENABLE  TMR1_INT  ; Enable Timer 1 Interrupts
    GOSUB ResetTime           ' Reset Timer and mSec_Ticks = 0
    IF tacc > 65 THEN
       cacc_div = 10
       cacc_div = 1
    cacc = ((1000/cacc_div) * tacc) / (ref - fmin)
    GOSUB StartTimer          ' Start Counting mSec_Ticks
         IF mSec_Ticks > (cacc * cacc_div) THEN
            IF freq < ref THEN freq = freq + 1
            mSec_Ticks = mSec_Ticks - (cacc * cacc_div)
            IF freq >= ref THEN
               GOSUB StopTimer
               GOSUB ResetTime
       IF PORTC.0=%1 THEN ref=500
    GOTO Main
    I may not be much use the next couple of days, but the building blocks are here (hopefully without too many errors/typos)
    Dec 2010
    Quote Originally Posted by pxidr84 View Post
    Hi Steve,
    Use a long for your variable - you'll have to work hard to overflow 32 bits.
    May 2006
    Del Rio, TX, USA
    Thanks for mentioning that Charlie! (I forgot too)
    It would certainly simplify the code. I went with the non-LONG method in the case that Pxidr84 might not have PBP3, and so no LONG variables. But yes, I would definitely use them if available. Either way, hopefully the methodology of the example is instructive in learning to scale integers to fit into the given variable space.
    Also, there is a correction I need to make to the code. I forgot an ENDIF:
            IF freq >= ref THEN
               GOSUB StopTimer
               GOSUB ResetTime
    Sorry about that.
