Linear acceleration ramp
Results 1 to 14 of 14
Threaded View
  1. #8
    May 2006
    Del Rio, TX, USA
    Default Re: Linear acceleration ramp
    Here is a start (not tested!). But it should get you going in the right direction. I only included the acceleration stuff to keep the logic simpler.
    You will need the include files (Get Darrel's from http://darreltaylor.com/DT_INTS-18/downloads.html), and make sure the file names match.
    ' PIC18F4431 initializationDEFINE OSC 40
    DEFINE LCD_DREG PORTD
    DEFINE LCD_EREG PORTB
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_EBIT 6
    DEFINE LCD_RSBIT 7
    tacc var BYTE
    tdec var BYTE
    cacc var word
    cdec var word
    ref var word
    fmin var word
    freq var WORD
    cacc_div VAR BYTE
    cdec_div VAR BYTE
    tacc=1
    tdec=10
    fmin=10
    ref=1200
    PAUSE 4000
    LCDOUT $fe,$1
    INCLUDE "DT_INTS-18.bas"
    INCLUDE "ReEnterPBP-18.bas"
    INCLUDE "TimerControl.pbp"  ; Timer Control Routines
            INT_Handler   TMR1_INT,  _UpdateTickCount,   PBP,  yes
    @   INT_ENABLE  TMR1_INT  ; Enable Timer 1 Interrupts
    GOSUB ResetTime           ' Reset Timer and mSec_Ticks = 0
    IF tacc > 65 THEN
       cacc_div = 10
       cacc_div = 1
    cacc = ((1000/cacc_div) * tacc) / (ref - fmin)
    GOSUB StartTimer          ' Start Counting mSec_Ticks
         IF mSec_Ticks > (cacc * cacc_div) THEN
            IF freq < ref THEN freq = freq + 1
            mSec_Ticks = mSec_Ticks - (cacc * cacc_div)
            IF freq >= ref THEN
               GOSUB StopTimer
               GOSUB ResetTime
       LCDOUT $fe,$2,DEC5 freq
       IF PORTC.0=%1 THEN ref=500
    GOTO Main
    I may not be much use the next couple of days, but the building blocks are here (hopefully without too many errors/typos)
