I discovered a new problem which I never seen or heard of before. My circuit works fine with the LCD hooked up. I removed the LCD restart and the pins output goes haywire..
I removed all the coding concerning the LCD in the program, did not work. Turns out, if I do not have 56 ohm resistance between the positive and negative, the circuit will not function properly. This resistance also need to be placed on the MCLR / ground rail !!!
here is the code I have, but I am not sure this will make a difference because the code does work with the 56ohm resistance..
Code:'using a pic16F88 - on cart trial module. ' MPASM Header INCLUDE "modedefs.bas" OSCCON = %01110000 '8 Mhz Define OSC 8 CMCON = 7 : ANSEL = 0 : ADCON1 = 7 ' Define ADCIN parameters Define ADC_BITS 8 ' Set number of bits in result Define ADC_CLOCK 3 ' Set clock source (3=rc) Define ADC_SAMPLEUS 50 ' Set sampling time in uS ADCON1 = %00000010 'for 8 bit value var word : variable var word : i var byte 'TRISA = %00000000 ' Set PORTA to all output TRISB = %10000000 PORTB.1 =0 PORTB.2 =0 PORTB.3 =0 PORTB.4 =0 mainloop: ADCON0.2 = 1 'Start Conversion ADCIN 6, value 'Read channel PORTB.7 pause 100 variable = 256 -value variable = variable *14 pause 30 i=1 while i<=variable PORTB.1 =1 PORTB.2 =1 PORTB.3 =1 'green led PORTB.4 =0 'red led i=i+1 pause 1000 wend i=1 while i<=variable PORTB.1 =0 PORTB.2 =0 PORTB.3 =0 'green led PORTB.4 =1 'red led i=i+1 pause 1000 wend goto MAINloop end
