Dallas 3231
Results 1 to 11 of 11
Thread: Dallas 3231
    May 2006
    Del Rio, TX, USA
    Default Re: Dallas 3231
    Something to remember with the DS3231, you need to write the address of the register you want to read first (no data)
    Then, when you read, you will get the data in the register.
    I've been happier using the hardware I2C. But try these PBP statments:
    I2CWRITE sda, scl, %11010000,%0
    I2CREAD sda, scl, %11010000, [seconds]
    Drat, no luck. I'll keep looking. Thanks!
    May 2006
    Del Rio, TX, USA
    I'll offer these up if you are interested in trying the hardware I2C if it's available on your device.
    Some things to mention:
    The path of the include file needs to be specified for where you have it saved.
    This is very bare bones and only ment to get you started in incorporating it into your own code.
    Steve,
    I am using a 16F88, which does have hardware I2C. Bummer is, I already made a PCB and populated it and the built in I2C pins are already in use. I think what I'll do is try the code you posted on a breadboard. If it works, I'll see if I can bodger up my board and switch the traces around.
    Thanks a lot for the help! I really appreciate it. I was sure it would be no prob as I have used this chip before and this project is so close to done.
    Jonathan
    Time to add the code I am trying, this has to be something dumb and obvious that I am doing wrong.
    mclr_on
    hs_osc '
    lvp_off
    wdt_off
    protect_off
    define OSC 20
    define shift_pauseus 100
    define I2C_slow 1
    lcdPin var portb.0
    lcdBaud con 84
    lcdAtn con $FE
    lcdOn con $41
    lcdCls con $51
    lcdContrast con $52
    lcdBackLight con $53
    lcdCursor con $45
    lineTwo con $40
    rtc CON %11010000
    sda var porta.1
    scl var porta.0
    SecReg CON $00 ' seconds address (00 - 59)
    ' MSB of SecReg must be set to a 0 to enable RTC
    MinReg CON $01 ' minutes address (00 - 59)
    HourReg CON $02 ' hours address (01 - 12) or (00 - 23)
    DayReg CON $03 ' day address (1 - 7)
    DateReg CON $04 ' date address (01 - 28/29, 30, 31)
    MonthReg CON $05 ' month address (01 - 12)
    YearReg CON $06 ' year address (00 - 99)
    StatusReg CON $0F
    cntrl CON $10'%00000110
    hours var byte
    minutes var byte
    seconds var byte
    days var byte
    month var byte
    year var byte
    date var byte
    hours = 12
    minutes = 55
    seconds = 14
    days = 0
    year = 0
    month = 0
    init:
    serout2 lcdpin,lcdbaud,[lcdAtn,lcdOn,lcdAtn,lcdcls,"DS3231 Test",_
    lcdatn,lcdCursor,lineTwo,"Version 0.1"]
    'I2cwrite sda,scl, RTC, $D0, $00,[seconds,minutes,hours,days,date,month,year,cntrl]
    'I2Cwrite sda,scl, RTC, StatusReg,[$0]
    'I2CWrite sda, scl, RTC, Secreg,[$00,$00]
    'I2CWrite SDA, SCL, RTC, StatusReg,[$00,cntrl]
    'I2CWrite portb.0, portb.1, $D0, $00, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate, RTCMonth, RTCYear, RTCCtrl]
    'I2CRead SDA, SCL, RTC, SecReg, [sec,MINs,hr,day,date,mon,yr]
    'I2CWrite SDA, SCL, RTC, SecReg,[sec,MINs,hr,day,date,mon,yr]
    'I2CRead sda,scl, RTC, secreg,[seconds,minutes,hours,days,date,month,year]
    'i2cread
    I2Cwrite sda,scl,%1101000,$0
    I2CRead sda,scl,%1101000,$0,[seconds]
    'I2CRead sda,scl, RTC, minReg,[minutes]
    serout2 lcdpin,lcdbaud,[lcdatn,lcdcls,dec2 hours,":",dec2 minutes,":",dec2 seconds,_
    lcdatn,lcdcursor,linetwo,dec2 month,"/",dec2 days,"/", dec4 year]
    May 2006
    Del Rio, TX, USA
    Port A is configured as analog input by default at power on (see note on pg 51 of datasheet), so you will need to include the following configuartion setting to make them digital:
    ANSEL = 0
    Check out this thread for more info
    Although this is likely just an issue of copy-paste from your IDE to the forum, but make sure you pay attention to case. For instance, DEFINES are case sensetive.
    And, for furture, you can use the "code" feature to post code. It is the "#" button in the tool bar of the forum posting window, or just type [code] ...your code here... [/code]
    Cool Re: Dallas 3231
    Steve,
    You da man! Ansel it was. Got it working, thanks so much! And now I can stop beating my head on the keybaord and get back to work.
    Jonathan
