pic16F628
Results 1 to 5 of 5
Thread: pic16F628
    May 2012
    Question pic16F628
    hi,can someone explain to me what this code does and how should i connect my lcd to pic16f628-with picture?
    thx
    'Name : Frekans-628.BAS *
    'Author : [Erol ERDAL) *
    DE@ DEVICE pic16F628
    @ DEVICE pic16F628, WDT_off
    @ DEVICE pic16F628, PWRT_ON
    @ DEVICE pic16F628, PROTECT_OFF
    @ DEVICE pic16F628, MCLR_ON
    @ DEVICE pic16F628, HS_OSCFINE OSC 10
    DEFINE LCD_DREG PORTA
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 2
    define LCD_RWREG PORTB
    DEFINE LCD_RWBIT 1
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 0
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 4000
    DEFINE LCD_DATAUS 250
    TRISA=0
    TRISB=111100
    fout var word
    foutL var fout.byte0
    foutH var fout.byte1
    mode var byte
    Delay VAR WORD
    Delay_Us var WORD
    x var word
    tenth var byte
    Z VAR BIT
    Z=0
    CMCON=7
    mode=0
    '************************* Main***************************
    START : GOSUB TUS 'this is for mode select
    SELECT CASE MODE
    CASE 0
    Delay=1000elay_Us=400
    GOSUB OLC
    Lcdout $FE,$1,"0-65 KHz : MOD=",DEC MODE
    Lcdout $FE,$C0,#fout," Hz":PAUSE 100
    goto START
    CASE 1
    Delay_US=100Delay=100
    GOSUB OLC :Fout=Fout/100
    Lcdout $FE,1,"65-650KHz: MOD=",DEC MODE
    Lcdout $FE,$C0,#fout," KHz":PAUSE 100
    GOTO START
    CASE 2
    Delay_US=996Delay=9
    GOSUB OLC:Fout=Fout/10:tenth=(fout//1000)/10
    Lcdout $FE,1,"650-6,5MHz:MOD=", DEC MODE
    Lcdout $FE,$C0,#fout/1000,",",#tenth," MHz":PAUSE 100
    GOTO START
    CASE 3
    Delay_US=992Delay=0
    GOSUB OLC:tenth=(fout//1000)/10:Fout=Fout/1000
    Lcdout $FE,1,"6,5-30 MHz:MOD=" ,DEC MODE
    Lcdout $FE,$C0,#fout,",",#tenth," MHz":PAUSE 100
    GOTO START
    END SELECT
    Z=0
    GOTO START
    TUS: PAUSE 70:if PortB.3=1 then
    IF Z=1 THEN CIK
    Mode=Mode+1pause 10
    IF MODE=4 THEN MODE=0
    Z=1
    Z=0
    CIK: RETURN
    ' ---------------frequency counting ------------------------------------
    OLC:
    if portb.6=0 then
    x=x+1
    if x>(Delay+Delay_Us) then return
    TMR1L=0
    TMR1H=0
    T1CON=7
    pause Delay
    pauseus Delay_US
    T1CON=6
    FoutL=TMR1L
    foutH=TMR1H
    Default Re: pic16F628
    Hello Daydream,
    Mostly this code demonstrates why "copy/paste" does not work well for newbies, example:
    So allow me to direct you to threads which will help you.
    the above thread explaines the first 6 lines of your code.
    BTW this code as listed probably will not work due to errors in those 6 lines, and those 6
    lines will only work in PBP 2.6 and below, as PBP 3. does not support
    PB assembler, only MPASM(read the listed thread carefully).
    now the lcd defines
    I will comment the code you listed so as to facilitate your understanding,
    BTW this IS IN THE BOOK.
    DEFINE LCD_DREG PORTA ' use port a for LCD
    DEFINE LCD_DBIT 0         ' first data bit on porta.0
                                         ' D4 or LCD pin 11
                                         ' so PortA.1 = D5, A.2 = D6,A.3=D7
    DEFINE LCD_RSREG PORTB 'LCD RS reg is on port B
    DEFINE LCD_RSBIT 2         'use PortB.2 as rs bit Pin4 on LCD
    define LCD_RWREG PORTB'LCD RW register is port B define should be ALLCAPS
    DEFINE LCD_RWBIT 1        'use PORTB.1 as read/write bit pin 5on LCD
    DEFINE LCD_EREG PORTB  'use PORTB as E register
    DEFINE LCD_EBIT 0         'use PORTB.0 for e bit pin 6 on LCD
    DEFINE LCD_BITS 4'tells compiler you are using 4 bit data
                               'you could be using 8 or a whole port
    DEFINE LCD_LINES 2 ' this is more confusing a typical 4 line LCD is really a 2 line
                                  ' cut in half and stacked together
    DEFINE LCD_COMMANDUS 4000 ' 4000 micro second delay
    DEFINE LCD_DATAUS 250         '250 micro second data delay
    TRISA=0                                 'sets all of portA to output status
    TRISB=%00111100' sets PortB.2:5 to input status
    'error as portb.2 should be an output
    fout var word ' make word variable named fout
    foutL var fout.byte0  'alias fout lower byte as foutL
    foutH var fout.byte1  'alias fout upper byte as foutH
    mode var byte  'create byte variable named mode
    Delay VAR WORD 'create word variable named Delay
    Delay_Us var WORD'create word variable named Delay_Us
    x var word 'create word variable named x
    tenth var byte 'create word variable named tenth
    Z VAR BIT'use up a byte to create a bit variable named Z
    Z=0' set value (initalize) bit variable to zero
    CMCON=7 'turn OFF analog comparators
    mode=0 ' set value (initalize) byte variable named mode to zero
    May 2012
    hi archangel,i have pic16f628a.what are comparators?how do I turn them off?with this CMCON=7?
    and if i connect my lcd and use a 4mhz cristal and pin RB6 for input,will lcd show the freq?
    thank you so much.
    try it, read the datasheet...
    Quote Originally Posted by daydream View Post
    A comparator is like an OP AMP, your 628A has them as analog inputs, so to use those pins as digital you disable them with in this case CMCON = 7
