Portc 16F913 problem
Results 1 to 4 of 4
    Default Portc 16F913 problem
    Hi all
    I am trying to use a PIC16F913 to read a keypad, the problem is i can not get PortC.2 to go to a high state ,can anyone please point me in a direction, Pin 0 and 1 works fine
    INCLUDE "MODEDEFS.BAS"
    Asm
        ERRORLEVEL -306
    Endasm
    DEFINE OSC 20    ' Define crystal as 20Mhz
    LCDCON = 0
    TRISC = %11110000   'Set PORTC for keypad
    TRISB = %00000000   'Sert PORTb as outputs and for use with the ICD2
    VAR1 VAR BYTE
    VALUE VAR BYTE
    PortB.0 = 0
    keyPad: portc=1
      if portc.4=1 then
      for VAR1=0 to 10
       if portc.4=1 then VAR1 = 0
      next
      VALUE=1
      goto getPin
      if portc.5=1 then
      for VAR1=0 to 10
       if portc.5=1 then VAR1 = 0
      next
      VALUE=4
      goto getPin
      if portc.6=1 then
      for VAR1=0 to 10
       if portc.6=1 then VAR1 = 0
      next
      VALUE=7
      goto getPin
      if portc.7=1 then
      for VAR1=0 to 10
       if portc.7=1 then VAR1 = 0
      next
      VALUE=10 '* button
      goto getPin
      portc=2
      if portc.4=1 then
      for VAR1=0 to 10
      next
      VALUE=2
      goto getPin
      if portc.5=1 then
      for VAR1=0 to 10
      next
      VALUE=5
      goto getPin
      if portc.6=1 then
      for VAR1=0 to 10
      next
      VALUE=8
      goto getPin
      if portc.7=1 then
      for VAR1=0 to 10
      next
      VALUE=0
      goto getPin
      portc=4
      if portc.4=1 then
      for VAR1=0 to 10
      next
      VALUE=3
      goto getPin
      if portc.5=1 then
      for VAR1=0 to 10
      next
      VALUE=6
      goto getPin
      if portc.6=1 then
      for VAR1=0 to 10
      next
      VALUE=9
      goto getPin
      if portc.7=1 then
      for VAR1=0 to 10
      next
      VALUE=11 '# button
      goto getPin
      goto keypad
    getpin:
    PortB.0 = 1
    Default Re: Portc 16F913 problem
    For starters, GETPIN is a subroutine, use GOSUB to call it, not GOTO.
    Thanks i'll do so - I did a bit of reading and it seems it has something to do with the "read modify write" functions on portC.2 and 5.
    I moved the pins to portB as they are spare and all seems to be working now
    Jun 2006
    Bangalore, India
    On 16F913, Port C is shared with the VLCD module. To uses this as digital I/O, you will need to clear the VLCDEN bit in LCDCON register.
