timer
Results 1 to 4 of 4
Thread: timer
    May 2012
    Unhappy timer
    can anyone with an example tell me how timer works in pic16f84.for example turning an led on using timer.i nead pbp code.please help.thank you very much.
    May 2012
    Default Re: timer
    can anyone write a pbp programmer using a timer intrupt to turn an led on after 60 seconds and explain how to use timer.i am using a 4mhz crystal and pic16f84a .i dont know anything about timer so please help.
    Default Re: timer
    Here is an example by famous tech writer Chuck . . . the article that went with it explains it pretty well.
    I am sure the issue is available, so are his books . . . May 2006
    http://www.nutsvolts.com/uploads/magazine_downloads/200605-Hellebuyck-timer1code.bas.txt
    Default Re: timer
    DT INTERRUPTS and timer:
    http://darreltaylor.com/DT_INTS-14/elapsed.html
