Adding a pic in I2C network....
Results 1 to 4 of 4
    Hangover, Germany
    Hello,
    your 16F876 ist the master,
    the Pcf8574 seems to be the slave.
    So your 16F84 is another slave !!!!!
    Your master has to poll the new slave !!!! No Interrupt !!!!
    Apr 2005
    Thanks for your help.
    Polling continuosly isn't the best (i think) but which serin and serout command?I mean how can both recognize each other?
    pcf8574 has a built in address(btw is 01110000) but how about the pics?
    roberto
    PICs can only act as MASTER using PICBASICs IC2READ and I2CWRITE commands.
    If you want to use a PIC as a SLAVE, then you need to write your own routines to do that. You can then assign whatever address you want to your SLAVE PIC - they don't come with a pre-assigned I2CSLAVE address because they don't come with integral I2CSLAVE software. It's up to YOU to create that software.
    I would refer you to Microchip Application Note AN734...
    http://ww1.microchip.com/downloads/e...tes/00734a.pdf
    But don't blindly copy it without understanding... there's some serious errors and omissions (as most Microchip Application Notes seem to have) that will prevent the code from operating correctly. However the theory is reasonably all in place.
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  4. Use pic as slave in I2C
    By robert0 in forum General
    Last Post: - 3rd February 2006, 20:26
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
