Pic887, New to programming, Clock.
Results 1 to 3 of 3
    Apr 2012
    Default Pic887, New to programming, Clock.
    Using PicBasic Pro (new to it this year) and I'm trying to make a relatively simple clock. I'm sure this code isn't that great and there are improvements I can make to it to make it shorter and more simple, but as of now it works ok.
    I'm using 3 2-7-Segment displays that are multiplexed.
    Anyways, here's the code I'm working off of (remember I just started, also this code still needs to add the 3rd set of 7 segments, but I could figure that out with the advancing from the first set!)
    Pretty much I need some help getting each set of 7 segments to count on their own, and then advance the count on the next digit, but making that set of 7 segments still count on their own timer. Hopefully that made sense. I'd like it to just be some tips on how to do it, but if you have to just tell me flat out, that works too.
    Thanks, if you have any questions I'll try to answer them the best I can, but remember I'm still new to this.
    (If this needs to be posted somewhere else, I will move it)
    Attachment 6445
    Default Re: Pic887, New to programming, Clock.
    There seems to be something wrong with the attachment so I can't look at your code and I'm not exactly shure what you're asking. Do you have a 6 digit display that will display elapsed time in seconds or do you have 3pcs of 2-digit displays that will all display elapsed time in seconds but independently of each other or do you have a 6 digit display that will display elapsed time in hours:minutes:seconds format?
    But basically, each time you increment a digit you check if it rolled over, if it did you increment the "next" digit, check if IT rolled over and so on. If you have three digits showing elapsed time in seconds then something like this:
    Ones = Ones + 1
      If Ones = 10 THEN   ' A single digit can only display 0-9
        Ones = 0
        Tens = Tens + 1
        If Tens = 10 THEN
          Tens = 0
           Hundreds = Hundreds + 1
    The same tecnique can be adopted to any number of digits, to hours:minutes:seconds or a countdown timer etc.
    Apr 2012
    Yeah sorry about being so unclear. I'm using 3 sets of 2-7 segment displays. I pretty much need the first digit to count and then from there I can just up the count on the others once that digit hits 10.
    Here's the code since I cannot get the attachment to ever work.
    Cnt var word
    Zero var Word
    Digit var word
    Pattern Var word
    digit1 var porta.0
    digit2 var porta.1
    digit3 var porta.2
    digit4 var porta.3
    digit5 var porta.7
    digit6 var porta.6
    First var word
    Second var word
    Third var word
    Fourth var word
    Fifth var word
    Sixth var word
    i var word
    ADCON1=7
    TRISA=0
    TRISB=0
    INTCON=%00100000
    OPTION_REG=%00000111
    TMR0=217
    ON INTERRUPT GOTO ISR
    INTCON=%10100000
    PHILL:
    CNT=0
    NXT:
    zero=0
    DIGIT=cnt DIG 5
    GOSUB CONVERT
    Fourth=~pATTERN
    DIGIT=cnt DIG 4
    GOSUB CONVERT
    Third=~PATTERN
    DIGIT=cnt DIG 3
    GOSUB CONVERT
    Second=~pATTERN
    DIGIT=cnt DIG 2
    GOSUB CONVERT
    First=~PATTERN
    DIGIT=cnt DIG 1
    GOSUB CONVERT
    Sixth=~pATTERN
    DIGIT=cnt DIG 0
    GOSUB CONVERT
    Fifth=~PATTERN
    FOR I=1 TO 10
    PAUSE 1
    NEXT I
    cnt=cnt+1
    Fifth = Fifth + 1
    If Fifth = 10 THEN
    Fifth = 0
    sixth = sixth + 1
    If sixth = 10 THEN
    sixth = 0
    First = First + 1
    GOTO NXT
    DISABLE
    ISR:
    TMR0=216
    portb=First
    digit5=0
    digit6=0
    digit4=0
    digit3=0
    DIGIT2=0
    DIGIT1=1
    PAUSE 1
    DIGIT1=0
    portb=Second
    DIGIT2=1
    PAUSE 1
    digit2=0
    portb=Third
    digit3=1
    PAUSE 1
    digit3=0
    portb=Fourth
    digit4=1
    PAUSE 1
    digit4=0
    portb=Fifth
    digit5=1
    pause 1
    digit5=0
    portb=Sixth
    digit6=1
    pause 5
    digit6=0
    INTCON.2=0
    RESUME
    ENABLE
    CONVERT:
    LOOKUP DIGIT,[$3F,$06,$5B,$4F,$66,$6D,$7D,$07,$7F,$6F],PATTERN
    PATTERN= PATTERN^$FF
    Any questions I'll try to answer. Sorry for my slow response.
