Sleep mode not functionning
Results 1 to 4 of 4
    Sep 2006
    Default Sleep mode not functionning
    I am trying to use the sleep command (assembler way) with and without the LCD as shown in my code. Either way it does not seem to work because without the LCD I always get 22mA from my 12v batteries and with the LCd module about 85mA . Can someone tell me why the sleep command do not work.
    I know I dont have any interrupt to get out of sleep, but first thing first
    ken
    'using a pic16F88
    ' MPASM  Header
    INCLUDE "modedefs.bas"
     OSCCON = %01110000 '8 Mhz
     Define OSC 8
    '// Interrupt section //
    'ON INTERRUPT Goto MyInterrupt
    ' INTCON = %10010000
    CMCON = 7 : ANSEL = 0 : ADCON1 = 7
    '// LCD configuration //
    DEFINE LCD_DREG PORTA ' Set LCD Data port
    DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTA ' Set LCD Register Select port
    DEFINE LCD_RSBIT 4 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTA ' Set LCD Enable port
    DEFINE LCD_EBIT 7 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    DEFINE CHAR_PACING 2000
    Mainloop:
     lcdout $FE,1, "Test: ", dec 22
     PAUSE 3000
    @sleep
    goto Mainloop
    Sep 2006
    Default Re: Sleep mode not functionning
    I read in a post that I needed to chang the GIE in the INTCON register.. so I did with no luck:
    INTCON.7 = 0 ' GIE = 1
    INTCON.4 = 1
    @ sleep
    Hi, Ken
    When talking about sleep mode current draw ...
    a full scheme AND full code of the project are highly necessary ...
    PS : I already bet 10 mA for your 12v/5v regulator ....
    Problem solved by a phone call
