PIC16F628 Port B.4 Problem
Results 1 to 5 of 5
    Default Re: PIC16F628 Port B.4 Problem
    Although your configuration shows LVP_OFF, it's possible that the configuration is not getting programmed into the chip.
    With LVP enabled, if B4 (PGM) goes high it puts the chip in programming mode.
    What programmer are you using?
    And is it set to program the configuration bits?
    Is it Port B.4 that you want to toggle? Port A has analog features, you have to disable them first.
    As it is, you set it high and leave it.
    By the way, you don't have to set B.4 high after setting all of Port B high, it's already high.
    EDIT: Aren't we supposed to use XT for 20mhz external oscillators? Can't remember, sure I read something about that tonight.
