MPLAB X, PBP3(demo) and DT-Int
Results 1 to 5 of 5
    Sep 2009
    Default Re: MPLAB X, PBP3(demo) and DT-Int
    Thanks Darrel...
    This is first time that I'm trying to use MPLAB-X. And I'm only trying to see how debugger works... And probably last time that I'll use...
    MCS is my favorite choice. I didn't try MCS plus, and its debugger, but I will...
    Hi, Darrel
    I got a little Headache with MPLABX :
    my program uses DT interrupts and a modified version of Elapsed INT. for external osc.
    'Includes
    INCLUDE "DT_INTS-18.bas"
    INCLUDE "ReEnterPBP-18.bas"
    INCLUDE "Elapsed_INT-18_ExtOsc.bas"  ; Elapsed Timer Routines
    Compiling fine with MPLAB 8.84 ...
    But, With MPLABX, I get the " Unable to open INCLUDE file Elapsed_INT-18_ExtOsc.bas " message ... ( the three include files are in the same folder )
    IF I replace the third file by " Elapsed_INT-18.bas " ( the genuine file ) ... Compilation starts and then occur the " double definition error " - quite normal to the day -
    Ok, let's call "Elapsed...ExtOsc" as "ELAPSED_INT-19.BAS" .
    WARNING: Unable to open INCLUDE file ELAPSED_INT-19.BAS.
    soooo, what might I understand ???
    Not to use MPLABX, Ok ... obvious ! ... BUT ...
