MPLAB X, PBP3(demo) and DT-Int
Results 1 to 5 of 5
    Sep 2009
    Default MPLAB X, PBP3(demo) and DT-Int
    I try to setup PICKIT3, MPLAB X, PBP3(demo) and it works...
    Then I try DT-Int hello world program and when I compile code with this line:
    @ INT_ENABLE INT0_INT
    result is:
    make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
    make[1]: Entering directory `D:/projects/Test 1/mplab/Test.X'
    make  -f nbproject/Makefile-default.mk dist/default/production/Test.X.production.hex
    make[2]: Entering directory `D:/projects/Test 1/mplab/Test.X'
    gnumkdir -p build/default/production
    "C:\PBP3\pbpx.exe"  -ampasmx -n -c -k# -v -os -p18lf46k80 TestPBP.pbp
    PICBASIC PRO(TM) Compiler 3.0.4.1, (c) 1998, 2011 microEngineering Labs, Inc.
    All Rights Reserved.
    Pass 1:
    C:\PBP3\DEVICES\PIC18LF46K80.PBPINC (556) MSG: LONG Variables enabled (PBPL used)
    Pass 2:
    Code Gen:
    Macro Pass:
    mpasmx /o- /s "D:\projects\Test 1\mplab\Test.X\TestPBP.ASM"
    COFF Pass:
    gnumkdir -p dist/default/production
    cp  TestPBP.HEX dist/default/production/Test.X.production.hex
    cp  TestPBP.COF dist/default/production/Test.X.production.cof
    rm -f  TestPBP.COF
    make[2]: Leaving directory `D:/projects/Test 1/mplab/Test.X'
    make[1]: Leaving directory `D:/projects/Test 1/mplab/Test.X'
    If I comment that line then it is ok..
    BUILD SUCCESSFUL (total time: 4s)
    Loading D:/projects/Test 1/mplab/Test.X/dist/default/production/Test.X.production.hex...
    Loading D:/projects/Test 1/mplab/Test.X/dist/default/production/Test.X.production.cof...
    Loading completed
    Sep 2009
    Default Re: MPLAB X, PBP3(demo) and DT-Int
    I found what it cause that errors...
    In DT_INTS-18.bas there are several ENDASM ASM...
    So when compiler found first it create label Z00029 then at next ENDASM ASM create label Z00029A, Z00029B and that cause duplicate label...
    That may have temporarilly solved your errors, but that is not the full problem.
    Please use this version of DT_INT-18 with MPLAB-X.
    http://support.melabs.com/threads/110
    Actually, don't use MPLAB-X. There are still too many bugs.
    Stick with MPLAB 8, and wait a year or 2. Maybe they'll work them out.
    Sep 2009
    Thanks Darrel...
    This is first time that I'm trying to use MPLAB-X. And I'm only trying to see how debugger works... And probably last time that I'll use...
    MCS is my favorite choice. I didn't try MCS plus, and its debugger, but I will...
    Hi, Darrel
    I got a little Headache with MPLABX :
    my program uses DT interrupts and a modified version of Elapsed INT. for external osc.
    'Includes
    INCLUDE "DT_INTS-18.bas"
    INCLUDE "ReEnterPBP-18.bas"
    INCLUDE "Elapsed_INT-18_ExtOsc.bas"  ; Elapsed Timer Routines
    Compiling fine with MPLAB 8.84 ...
    But, With MPLABX, I get the " Unable to open INCLUDE file Elapsed_INT-18_ExtOsc.bas " message ... ( the three include files are in the same folder )
    IF I replace the third file by " Elapsed_INT-18.bas " ( the genuine file ) ... Compilation starts and then occur the " double definition error " - quite normal to the day -
    Ok, let's call "Elapsed...ExtOsc" as "ELAPSED_INT-19.BAS" .
    WARNING: Unable to open INCLUDE file ELAPSED_INT-19.BAS.
    soooo, what might I understand ???
    Not to use MPLABX, Ok ... obvious ! ... BUT ...
