IR decoder Sony code Help
Results 1 to 11 of 11
    Nov 2006
    Brooklyn,NY
    Default Re: IR decoder Sony code Help
    Check : www.rentron.com It will save you a lot of time if you just want to build a Sony decoder and use it to control something.
    Schlaray.
    Apr 2012
    I would order one of those, I took a look there. However, I had to create a custom circuit board for a class and am basing my work on that. I'm making an SPDIF/Optical audio switcher. I presented everything for the class and it wasn't working, however, the main reason I wanted to build this is so that I could use it. So it needs to be able to fit the circuit board I have, so I'm kind of stuck doing what I'm trying now.
    Anyone else have any ideas? Thanks for the ideas so far. Does the code look correct? or does it need to change?
    Can you give us a "fresh" copy of the code, exactly as you have it right now so we can see what you have, I was unaware of some quirks in vbulletin and probably messed up your original posting, I could fix it but then I wouldn't know if it is what you have now.
    Apr 2012
    This is the current code I moved the LCD initialization before main: I believe that would work.
    'Program SONY_RX.BAS
    ' * For use with EXPERIMENTING WITH THE PICBASIC PRO COMPILER *
    ' *  This source code may be freely used within your own      *
    ' *  programs. However, if it is used for profitable reasons, *
    ' *        please give credit where credit is due.       *
    ' *  And make a reference to myself or Rosetta Technologies   *
    ' *   Les. Johnson         *
    'This program reads signals from a Sony IR remote control,
    'and displays them on a Serial LCD, connected to PortA.0 at inverted 9600 Baud 8-N-1
    'The infrared receiver module used is the Sharp GP1U58X.
    'The infrared receiver module for this experiment should,
    'be a type that is set for a 38 kHz carrier frequency.
    'If another type is used. some reduction in range may be noticed.
    'The output pin of the IR module connects to PortB.0
    'The remote control used, may be either a Sony manufactured unit,
    'or one of the universal remotes that can be configured for Sony equipment.
    'This is important since we are dealing with a specific signal protocol.
    'With Sony’s SIRCS specification, a start pulse is initially sent to
    'indicate the beginning of a frame of data. This pulse is approx 2.5 msec in length.
    'Following this, are 7-bits of data, which represent the instruction being sent.
    'Then an additional 5-bit command byte, which signifies the target device (TV, VCR, etc.).
    'Data bits are sent with the least significant bit first.
     Include "Modedefs.Bas"
    ' ** Setup the Crystal Frequency, in Mhz **
     Define  OSC  4  ' Set Xtal Frequency
    ' ** Declare the Variables **
        CMCON = 7
     IR_Sense  Var     PortB.4        ' The IR sensor is attached to this pin
     ST       Var     Word     ' Header length, signal
     IR_Word  Var St  ' Double up the variable, to save ram
     ID  Var Byte  ' The sony bit length 600us = 0, 1200us = 1
     IR_Data  Var Byte  ' The data byte returned
     IR_Dev  Var Byte  ' The command byte returned
     Sony_LP  Var Byte  ' Temporary variable used for a loop
     IR_Valid Var Bit  ' Flag to indicate a valid signal has been received
    'initialize NEWHAVEN NHD-0208AZ-RN-YBW
    '=================  ' 2x8 LCD display
         ' LCD DEFINES FOR USING 2x8 LCD with PortA
               DEFINE LCD_DREG PORTB    ' Use PORTA for LCD Data
               DEFINE LCD_DBIT 0        ' Use lower(4) 4 bits of PORTB
                                          ' PORTA.0 thru PORTA.3 connect to
                                          ' LCD DB4 thru LCD DB-7 respectively
               DEFINE LCD_RSREG PORTA   ' PORTA for RegisterSelect (RS) bit
               DEFINE LCD_RSBIT 3       ' PORTA.4 pin for LCD's RS line
               DEFINE LCD_RWREG PORTA   ' LCD read/write port
               DEFINE LCD_RWBIT 4       ' LCD read/write bit
               DEFINE LCD_EREG PORTA    ' PORTA for Enable (E) bit
               DEFINE LCD_EBIT 7        ' PORTA.5 pin for LCD's E line
               DEFINE LCD_BITS 4        ' Using 4-bit bus
               DEFINE LCD_LINES 2       ' Using 2 line Display
               DEFINE LCD_COMMANDUS 10000' Command Delay (uS)
               DEFINE LCD_DATAUS 100     ' Data Delay (uS)
        ' DEFINE LCD Control Constants
               Line1   CON 128          ' Point to beginning of line 1 ($80)
               Line2   CON 192          ' Point to beginning of line 2 ($C0)
        ' Test the LCD during initialization
               LCDOut $fe,1:FLAGS=0:Pause 250    ' Clear Display
               LCDOut $fe,Line1,"LCD TEST"       ' Display on 1st line
               Pause 500
               LCDOut $fe,Line2,"Power On!"      ' Display on 2nd line
               PAUSE 1000
     Gosub Sony_In     ' Receive the remote control signal
        If IR_Valid=1 then    ' Do the following code, if a valid packet has been received
    ' Display the data Byte (7-bit code), and the command byte (5-bit code)
            lcdout $FE, 1, "Data"
            lcdout $FE, 1, BIN IR_Data
            lcdout $FE, $C0, bin IR_Dev
     Endif
            Goto Main     ' Loop Forever.
    ' The subroutine "SONY_IN", receives the signal from a Sony remote control,
    ' and returns with the 7-bit data byte in the variable "IR_DATA",
    ' and the 5-bit command byte in the variable "IR_Dev".
    Sony_In:
     TrisB.4=1    ' Set the sensor pin to input
     IR_Valid=1    ' Initialize the valid data flag
     If IR_Sense=0 then goto No_Sig   ' We are already in the middle of a pulse so, exit
            IR_Word = 0:IR_Data=0:IR_Dev=0         ' Clear the variables used within the subroutine
            Pulsin IR_Sense,0,ST   ' Measure the header length.
            If St < 200 then goto No_Sig     ' Verify a good start bit, should be approx 240-260, using a 4mhz Crystal
            If St > 270 then goto No_Sig        ' If not valid then return with "IR_DATA"=255
    ' Receive the 12 data bits (LSB first), and convert them into a 12-bit word,
    ' A high (1) should be approx 120, actual timing is 1200 us
    ' A low (0) should be approx 60 , actual timing is 600 us
    ' We split the difference and say that < 100 is a low, >= 100 is a high
    ' These values are for use with a 4mhz crystal
     For Sony_Lp=0 to 11   ' Do 12-bits
     Pulsin IR_Sense,0,ID   ' Receive the IR bit pulse
     If ID>=100 then
     IR_Word.0[Sony_Lp]=1   ' If it's greater than 100 then we have received a 1
     Else
     IR_Word.0[Sony_Lp]=0   ' If it's less than 100 we have received a 0
     Endif
     Next      ' Close the loop
    ' Split the 7-bit data byte, and the 5-bit command byte
     IR_Data=IR_Word & %01111111  ' Mask the first 7 "DATA" bits
     IR_Dev=(IR_Word >>7)&%00011111  ' Move down and mask the last 5 "COMMAND" bits
     Return     ' Exit the subroutine
    No_Sig:
     IR_Valid=0    ' Indicate, No signal detected
     Return     ' was detected
    Ok move this up above main TrisB.4 = 1 ' Set the sensor pin to input
    and add this TRISA = %00000000 ' up there too
    Check your defines RS bit cannot reside on PortA.3 as it is used as a data bit, you could move it to portB
    Jun 2006
    Bangalore, India
    A nice encoder and decoder implemented in PBP (SIRC protocol).
    http://www.rentron.com/PicBasic/IR_Chips.htm
    This is pretty old, but should work if you have a standard 12-bit type Sony IR transmitter. It's one of the simplest routines I have for decoding Sony IR.
    IR_PULSE VAR BYTE(12) ' IR data received
    INDEX VAR BYTE        ' Index pointer
    DBYTE VAR BYTE        ' IR data received
       PULSIN PORTC.3,0,IR_PULSE         '// Read-in start pulse
       IF (IR_PULSE < 200) OR (IR_PULSE = 0) THEN Main
    Verify:                              '// Read, Decode, then verify data
       FOR Index = 0 TO 11               '// Setup to read-in 12 pulses
        PULSIN PORTC.3,0,IR_PULSE[Index] '// Read 12 low-going pulses on C3
       NEXT Index                        '// Loop x times
       DBYTE = $7F                       '// Start with all 1's and find each 0
       FOR Index = 0 TO 6                '// Get 7 "data" bits
        IF IR_PULSE[Index] < 100 THEN DBYTE.0[Index]=0 '// Less than 1mS = 0
       NEXT Index
       DBYTE = DBYTE + 1                 '// Button code #1 = 0, Button #2 = 1, so add 1
                                         '// for actual button pressed for display
       HSEROUT ["Button #",#DBYTE," was pressed",13,10]
       GOTO Main
    It's easy to change to pretty much any I/O-pin you want.
    -Bruce
    tech at rentron.com
