I ordered the MRF24WB0MA with the daughterboard to play with. I thought it would come with more documentation that just the pinout of the board. After seeing a 2009 post on here about this same module that had no replies this is not looking to good.
The MRF24WB0MA is a very basic radio module with some encryption hardware.
It does not have a TCP/IP stack built-in, and requires the use of Microchip's TCP/IP stack that is only available in C.
Using it with PBP will be very difficult.
Thanks Darrel, well thats money down the drain. What would you recommend for something I can see on the pc wireless network that I could broadcast an ID every so often? That would be pretty cool for a fox hunt. But thank you for clarifying the dreadful "C" issue, I assumed automatically that because it was from Microchip....well you now know the rest of the story. Thanks again.
Could you clarify what "broadcast an ID every so often?" means.
Modules that can do an "Ad-hock" connection will broadcast it's SSID.
But I'm not sure if that's what you want.
yes, that would be fine. It would be nice if all I had to do was power up the module and the SSID would broadcast but I would have to time it out so my battery would not be exhausted prematurely. Thanks Darrel
Roving Networks, RN-131 or RN-171.
http://www.rovingnetworks.com/products/Wi_Fi_Modules
I'm currently using the 171.
Microchip Technology Acquires Roving Networks as of April 19th 2012.
Norm
