ICSP Newbie
Results 1 to 12 of 12
Thread: ICSP Newbie
    Mark Scotford's Avatar
    Mark Scotford Guest
    Wink ICSP Newbie
    Going over from EPROM Pics to FLASH devices for deveopment, need a little help please. I bought a ELNEC Pikprog+ ICP programmer for this purpose, I 've isolated the VPP from the Reset circuit using a diode, have not used the RB6+7 pins for anything else, the bit I don't understand is the resistor shown in the Microchip guide on ICSP programming. It shows a resistor connecting VDD of the PIC to the supply voltage, I presume this is to allow the programmer to raise and drop the supply voltage to the PIC, when it is verifying. My question, is this resistor left in circuit once the PIC has been programmed? if so what is a safe value to use for this resistor? would a diode not be a better solution? TIA
    in my case i never use that method as Microchip suggest. what i use is something like this. Not much.
    Hangover, Germany
    I have managed to use ICSP in my current devices.
    I take a 100K-resistor from VDD to MCLR, so I can connect ICSP to MCLR direct.
    RB6 and RB7 are connected to the ICSP and have 100K Pullups for normal function of the device.
    100K are like isolation for the signals.
    5V is connected through a 1N5818 to the PICs VDD, and this signal is connected to ICSP.
    garret's Avatar
    garret Guest
    Thumbs up icsp solution
    AS always, simplicity is the nicest of methods.
    Do a search for melanies icsp attachment. You will find it in this forum and it demonstrates simplicity and effectiveness.
    I've triedit and use it almost all the time...
    Mark Scotford Guest
    Red face Too Simple?
    I took time to search for Melanies ICSP method, and I think it maybe too simple for my programmer. If I understand things correctly, my programmer raises and lowers the VDD to my PIC (but cannot, because I have hard wired my PIC's VDD, to the supply rail, and is clamped to +5V by my 7805 regulator), to verfiy after programming, that the code has "taken" with all possible supply voltages (I only ever use +5V, but try telling my ELNEC programmer that). When ever I try using the ICSP set-up I am currently using, my ELNEC programmer comes back saying that programming could not be verifyed correctly, and I presume this is because of this VPP raising/lowering problem I have been talking about. ELNEC have told me to consult the Microchip data sheet on ICSP programming, and this is where this thread originates from, can any body help me on this with the correct implementation of the Microchip ICSP protocol/method etc??0
    BTW there's no reason to take your VDD from your programmer.
    In your programmer software, you should be able to disable some tests like voltage testing (at xyz voltage(s)).
    Did you try to erase the device before programming?
    Is this programmer have also an ISP connector?
    Are you saying that because something is 'simple' it shouldn't work? I use Elnec although a different model... the software however is probably the same... When you Click PROGRAM DEVICE... select DEVICE OPERATION OPTIONS... therein you will be able to select your Verify and Voltage options.
    >> If I understand things correctly, my programmer raises and lowers the VDD to my PIC (but cannot, because I have hard wired my PIC's VDD, to the supply rail, and is clamped to +5V by my 7805 regulator)...
    This is the equivallent of "I have my Ferrari tied to a 1 ton concrete block and I can't reach 100mph in 6.5 seconds anymore - can anyone suggest what I can do?".
    So you KNOW what your problem is... don't waste time looking for non-existant solutions to a problem you are clearly aware of. If you have VDD on your PIC strapped directly to the +5v rail without a blocking Diode, you are effectively telling the Elnec to power your entire PCB... you're lucky it's not tripping an "Overcurrent Error". No wonder you're getting a Verify failure!
  1. ICSP and 16F684
    By onaclov2000 in forum Schematics
    Last Post: - 5th March 2009, 18:31
  2. Soic Icsp
    Last Post: - 13th September 2008, 20:51
  3. Replies: 1
    Last Post: - 11th December 2007, 00:57
  4. ICSP Programming from a PDA
    By Ralph in forum Off Topic
    Last Post: - 11th November 2007, 23:22
  5. PIC18F2550 ICSP - newbie
    By icicle in forum Off Topic
    Last Post: - 9th August 2005, 23:41
