Going over from EPROM Pics to FLASH devices for deveopment, need a little help please. I bought a ELNEC Pikprog+ ICP programmer for this purpose, I 've isolated the VPP from the Reset circuit using a diode, have not used the RB6+7 pins for anything else, the bit I don't understand is the resistor shown in the Microchip guide on ICSP programming. It shows a resistor connecting VDD of the PIC to the supply voltage, I presume this is to allow the programmer to raise and drop the supply voltage to the PIC, when it is verifying. My question, is this resistor left in circuit once the PIC has been programmed? if so what is a safe value to use for this resistor? would a diode not be a better solution? TIA
