I really, really, really need help with this code!!
Results 1 to 8 of 8
    Mar 2011
    Los Angeles, California
    Default I really, really, really need help with this code!!
    Hello Everyone!
    I have been struggling, researching, and struggling trying to get this code to work. Nothing seems to work correctly. My sincere hope and wish is that someone's expert eyes will spot the errors. Okay, so I went to set all the inputs to digital using ADCON1 = 7. As soon as I did this the program stops right after this statement. I tried looking with an oscilloscope at signals such as the SCLK and nothing seems to be there! Hour after hour, day after day I have been banging my head against the wall (and not because it feels good when it stops hurting, Lol) and I must now admit I am completely stuck. Any and all input will be more than appreciated. Thanks, Ed
    DEFINE OSC 20 'Define crystal frequency
    DEFINE CCP1_REG PORTB ' Use CCP1 for 32768 master clock PORTB.3
    DEFINE CCP1_BIT 3 ' Use CCP1 for 32768 master clock PORTB.3
    Include "Modedefs.bas"
    __CONFIG _CONFIG1H, _HS_OSC_1H & _FSCM_OFF_1H
    __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_32K_2H
    __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _BORV_27_2L
    __CONFIG _CONFIG3H, _MCLRE_OFF_3H
    __CONFIG _CONFIG4L, _DEBUG_OFF_4L & _LVP_ON_4L & _STVR_ON_4L
    __CONFIG _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L
    __CONFIG _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    __CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L
    __CONFIG _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    __CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L
    __CONFIG _CONFIG7H, _EBTRB_OFF_7H
    '********************* Declaired Pins **************************
    Dout VAR PortA.0 'data out from the MS5541
    Din VAR PortA.2 'data in to the MS5541
    Sclk VAR PortA.3 'MS5541 32.768 khz clock
    Mclk VAR PortB.3 'MS5541 Master clock for the MS5541
    ADCON1 = 7
    TRISA.0 = 1 ' Make A.0 an input YEL
    TRISA.2 = 0 ' Make A.2 an output GREEN
    TRISA.3 = 0 ' Make A.3 an output (Sclk) BLUE
    TRISB.3 = 0 ' Make B.3 an output (CCP2) VIOLET
    '************** Intersema Variables *********************************
    C1 var word ' 5540 Pressure sensitivity
    C2 var word ' 5540 Pressure Offset
    C3 var word ' 5540 Temp Coef of pressure sensitivity
    C4 var word ' 5540 Temp Coef of Pressure Offset
    C5 var word ' 5540 Reference temperature
    C6 var word ' 5540 temp coef of Temp reading
    ' C1 to C6 are in EEROM as VAL.byte0, VAL.byte1 from 108 to 159
    D1 var word ' raw pressure word from Intersema sensor
    D2 var word ' raw temperature word
    D1Flag var bit
    W1 var word 'coefficient from 5540
    W2 var word 'coefficient from 5540
    W3 var word 'coefficient from 5540
    W4 var word 'coefficient from 5540
    ' W1 to W4 are NOT stored in EEROM - they are not needed again.
    dT var long ' intermediate calc value
    dT1 var long ' intermediate calc value
    dT2 var long
    UT1 var word ' Calibration temperature
    II var byte ' used ONLY within Intersema routines
    IJ var byte
    IK var byte
    IL var byte
    ILoop var word
    CalFlag var bit ' EEROM 99. Used to reduce wear on EEROM
    temp2 var word
    ClkChk var word ' = 8192 if IntRC clock is exactly on frequency
    TimeFlag var bit
    TempRead var word
    CntRem var word
    CntPerC var word
    d var BYTE[18]
    IW var long
    IX var long
    IY var long
    IZ var long
    T2 var long ' Second order Temperature correction
    P2 var long ' Second order Pressure correction
    Offset var long
    Senstvty var long
    Pressure var long '
    Celsius var long 'a LONG allows negative temperatures
    ' Set all variables to a known number
    C1 =0
    C2 =0
    C3 =0
    C4 =0
    C5 =0
    C6 =0
    D1 =0
    D2 =0
    D1Flag =0
    W1 =0
    W2 =0
    W3 =0
    W4 =0
    dT1 =0
    dT2 =0
    UT1 =0
    II =0
    IJ =0
    IK =0
    IL =0
    ILoop =0
    CalFlag =0
    temp2 =0
    ClkChk =0
    TimeFlag =0
    TempRead =0
    CntRem =0
    CntPerC =0
    d =0
    IW =0
    IX =0
    IY =0
    IZ =0
    T2 =0
    P2 =0
    Offset =0
    Senstvty =0
    Pressure =0
    Celsius =0
    goto endofsubroutines ' jump subroutines at startup
    '*************************** Subroutines *****************************
    ResetIntersema:
    ' need 32768 @ 50% for Intersema on CCP2.
    hpwm 1, 127, 32767
    pause 50
    shiftout din, sclk, 0, [85, 85, 0\5] ' Sense of Din is IN to 5541
    pauseus 100
    'return
    FetchWord:
    shiftin dout, sclk, 2, [ij, ii, ik\1]
    ' IJ is hi byte, II is lo byte, IK is a dummy and discarded
    'return
    CalSensor:
    read 99, calflag : if calflag = 1 then calsensordone
    ' debug 13, 10, "Fetch Intersema data", 13, 10
    ' This fetches and unpacks the factory calibration coefficients
    ' from W1 ~ W4. W values need not be stored.
    ' These bitmaps are unpacked into the 6 working coefficients
    ' C1 to C6 which must be stored in EEROM for later use.
    ' W1
    gosub resetintersema
    shiftout din, sclk, 0, [87, 1\5] ' Send W1 pattern to all sensors
    gosub fetchword ' get reply
    W1.byte0 = ii
    W1.byte1 = ij
    ' W2
    shiftout din, sclk, 0, [215, 0\5] ' Send W2 pattern
    gosub fetchword
    W2.byte0 = ii
    W2.byte1 = ij
    ' W3
    shiftout din, sclk, 0, [55, 1\5] ' Send W3 pattern
    gosub fetchword
    W3.byte0 = ii
    W3.byte1 = ij
    ' W4
    shiftout din, sclk, 0, [183, 0\5] ' Send W4 pattern
    gosub fetchword
    W4.byte0 = ii
    W4.byte1 = ij
    ' Unpack W1 ~ W4 into C1 ~ C6 coefficients
    ' C1
    C1 = W1 >> 3
    write 108, c1.byte0
    write 109, c1.byte1
    ' C2
    C2 = ((W1 & %0000000000000111) << 10) + (W2 >> 6)
    write 110, c2.byte0
    write 111, c2.byte1
    ' C3
    C3 = W3 >> 6
    write 112, c3.byte0
    write 113, c3.byte1
    ' C4
    C4 = W4 >> 7
    write 114, c4.byte0
    write 115, c4.byte1
    ' C5
    C5 = ((W2 & %0000000000111111) << 6) + (W3 & %0000000000111111)
    write 116, c5.byte0
    write 117, c5.byte1
    ' C6
    C6 = W4 & %0000000001111111
    write 118, c6.byte0
    write 119, c6.byte1
    ' high pgc : pause 1
    ' debug "Intersema Factory data ", $0D, $0A, "W1 = ,"_
    ' , #w1, ", W2 = ,", #w2, ", W3 = ,", #w3, ", W4 = ,", #w4, $0D, $0A
    ' debug "Derived coefficients", $0D, $0A, "C1 = ,", #C1, ", C2 = ,", #C2,_
    ' ", C3 = ,", #C3, ", C4 = ,", #c4, ", C5 = ,", #C5, ", C6 = ,", #C6.byte0,_
    ' $0D, $0A
    ' read 99, calflag : if calflag = 0 then write 99, 1
    CalSensorDone:
    ReadIntersema: '
    ' D1 is Pressure - D2 is Temperature
    ' Uses LONG datatype to handle negative temperatures
    ' This routine reads the sensor and returns Pressure word
    ' and Celsius long
    ' A, II, IJ, W and X are all destroyed
    ' D1
    shiftout din, sclk, 0, [47, 0\5] ' Select D1 pattern
    While dout = 1
    wend 'Convert5541Delay:
    gosub fetchword
    ' This returns ii = lobyte, ij = hibyte from the sensor
    D1.byte0 = ii
    D1.byte1 = ij
    ' D2
    shiftout din, sclk, 0, [79, 0\5] ' Select D2 pattern
    While dout = 1
    wend
    gosub fetchword
    D2.byte0 = ii
    D2.byte1 = ij
    CalcTempPress: ' 32 bit signed arithmetic version. Handles negatives.
    read 108, c1.byte0
    read 109, c1.byte1
    read 110, c2.byte0
    read 111, c2.byte1
    read 112, c3.byte0
    read 113, c3.byte1
    read 114, c4.byte0
    read 115, c4.byte1
    read 116, c5.byte0
    read 117, c5.byte1
    read 118, c6.byte0
    ' formulae for DS5541 are NOT the same as for DS5540
    ut1 = 8*c5 + 10000
    dt = d2 - ut1
    Celsius = 200 + dt*(c6 + 100)/2048
    offset = c2 + ((c4 - 250)*dt)/4096 +10000
    senstvty = c1/2 + ((c3 + 200)*dt)/8192 + 3000
    pressure = (senstvty * (d1 - offset))/4096 + 1000
    ' NOT applying second order temperature correction in this version.
    ' Note 2nd order correction formula ambiguity in datasheet.
    if celsius < 0 then 'high bit of 32 bit number is set
    temp2 = 1000 - celsius
    temp2 = 1000 + celsius
    d[17] = temp2.byte0
    d[18] = temp2.byte1
    if calflag = 0 then
    ' debug "MS5541 Celsius = ", sdec Celsius/10, ".", dec1 celsius//10, _
    ' ", Pressure = ", dec pressure, " mBar, recorded as ",_
    ' dec temp2, 13, 10
    ' return
    EndOfSubRoutines:
    ' *********************** Initialise *****************************
    FetchDepth:
    gosub readintersema
    ' debug "T2 = ", dec temp2, 13, 10
    ' debug dec (temp2 - 1000)/10, ".", dec1 (temp2 - 1000)//10, _
    ' ", ", #pressure, " mBar", 13, 10
    ' this returns Pressure & Celsius, both words.
    Miami, Florida USA
    Default Re: I really, really, really need help with this code!!
    What PIC are you using?
    Also, every subroutine should end with a RETURN statement, so you can return to the point where your code was at when calling the GOSUB. At the end of your program you need a GOTO FetchDepth.
    Anonymous
    Mar 2011
    Thank you! Thank you! Thank you! It is a 18F1320. For some reason (probably a brain cramp) I commented out the returns!
    Mar 2011
    At the risk of sound more dumb than I already have, There are statements such as:
    ' D1
    While dout = 1
    and the program seems to stop at the wend??
    Short that pin to GND and se what happen
    Mar 2011
    Okay and if I short it to gnd then the program continues to run. Comment out the WHILE and WEND statements things will run to a point where the program goes all the way back to the #config! Please note that I did not write this program, just trying to get it to function and there is a ton I simply do not understand. Thanks, Ed
