setting config fuses not working
Results 1 to 7 of 7
    Jun 2011
    Indian Harbour Nova Scotia
    Default Re: setting config fuses not working
    Thanks, I did find that in the manual on page 97 while I was waiting for a reply.
    This is what I've got: (space in column 1)
    #config
    __CONFIG _INTRC_OSC_NOCLKOUT
    __CONFIG _INTOSC_OSC_NOCLKOUT
    #endconfig
    I don't get compile errors with this syntax, but I get an ASM error "Overwriting previous address contents". As a result the Meprog programmer menu doesn't open (because of the error). I open the programmer manually and program. All is well...except the program doesn't work. It's at this point where I can change the bits in the programmer configuration menu to INTOSCIO and the program does work.
    Hi queenidog.
    You will have to pick either one, but not both.
    Either use
    #config
    #endconfig
    or
    #config
    #endconfig
    Depending on which one you want to use, probably INTOSC.
    The options Are:
    ; __CONFIG labels for PIC16F628A:
    ;CONFIG Options
    ; Oscillator Selection bits
    ; _RC_OSC_CLKOUT ;RC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, Resistor and Capacitor on RA7/OSC1/CLKIN
    ; _ER_OSC_CLKOUT ;RC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, Resistor and Capacitor on RA7/OSC1/CLKIN
    ; _RC_OSC_NOCLKOUT ;RC oscillator: I/O function on RA6/OSC2/CLKOUT pin, Resistor and Capacitor on RA7/OSC1/CLKIN
    ; _ER_OSC_NOCLKOUT ;RC oscillator: I/O function on RA6/OSC2/CLKOUT pin, Resistor and Capacitor on RA7/OSC1/CLKIN
    ; _INTOSC_OSC_CLKOUT ;INTOSC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    ; _INTRC_OSC_CLKOUT ;INTOSC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    ; _INTOSC_OSC_NOCLKOUT ;INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    ; _INTRC_OSC_NOCLKOUT ;INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    ; _EXTCLK_OSC ;EC: I/O function on RA6/OSC2/CLKOUT pin, CLKIN on RA7/OSC1/CLKIN
    ; _HS_OSC ;HS oscillator: High-speed crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN
    ; _XT_OSC ;XT oscillator: Crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN
    ; _LP_OSC ;LP oscillator: Low-power crystal on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN
    http://www.scalerobotics.com
    Jun 2011
    Well hot damn, it this didn't work! Thanks.
    I guess I didn't understand the difference between the two so picking both was a good thing. (I did this with two girlfriends once when I was in grade IV, they both ended up hating me).
    So what is the difference? I used intosc.
    You raise a good question. Looking into it further, there is no difference. I looked at the data sheet, and it says you have 8 options:
    111 = RC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, Resistor and Capacitor on RA7/OSC1/CLKIN
    110 = RC oscillator: I/O function on RA6/OSC2/CLKOUT pin, Resistor and Capacitor on RA7/OSC1/CLKIN
    101 = INTOSC oscillator: CLKOUT function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    100 = INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    011 = EC: I/O function on RA6/OSC2/CLKOUT pin, CLKIN on RA7/OSC1/CLKIN
    010 = HS oscillator: High-speed crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN
    001 = XT oscillator: Crystal/resonator on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN
    000 = LP oscillator: Low-power crystal on RA6/OSC2/CLKOUT and RA7/OSC1/CLKIN
    Then looking at the .info file, it shows 20 options, which doesn't quite make sense. Looking closer, we have to look into the microchip .inc files, located here: C:\Program Files (x86)\Microchip\MPASM Suite\P16F628A.inc
    Here there are 3 internal options with no clockout which all have the same EQU number.
    _FOSC_INTOSCIO       EQU  H'3FFC'    ; INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    _INTOSC_OSC_NOCLKOUT EQU  H'3FFC'    ; INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    _INTRC_OSC_NOCLKOUT  EQU  H'3FFC'    ; INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    So, I guess you can use any one of the above and get the same result.
    Jun 2011
    More info:
    You said to "use either but not both" and that's good advice because if I use EITHER, it works. If I use both, it don't work!
    I used INTOSC because it was more "intuitive" in the language. I think the INTRC is an older term that was "deprecated" as they say, but still works for compatibility.
    Either one works, but not at the same time.
