help with electronic question
Results 1 to 4 of 4
    Feb 2012
    PERTH AUSTRALIA
    Default help with electronic question
    Hi guys ,
    would like to confirm with those more knowledgeable on the electronics side of life a problem i am having with looking for an equivalent mosfet for a repair
    The componet is a VN0106N5 which has a signal on the gate of 13.5mhz and is faulty ,
    Looking at the possible replacement for VN0106N5 and the IRF510-512 series came up in searches
    given the input to gate of 13.5mhz gives a 74ns cycle , half a cycle is 37ns
    rise half cycle is = turn on delay time + rise time
    fall half cycle is turn off delay + fall time
    thus spec for IRF510 -513 series says
    max rise turn on delay =20ns
    max rise time =25ns ,
    same for for fall times
    so half cycle rise time is max 45ns , fall half cycle is 45ns , i need a max of 37ns at a freq at 13.5mhz
    thus this equivilant mosfet wont fit this application
    am i correct in my calculations ??
    cheers
    Dec 2007
    Finland
    Default Re: help with electronic question
    Sine waves have predictable shape and timing so rise/fall time (10-90%) can be calculated fairly easy.
    RiseTime = (arcsin(0.8))/(PII*Freq) = ~0.2952/Freq -> ~0.3*Period
    RiseTime = 74ns * 0.3 = ~22ns
    Your FET rise/fall time need to be faster that 22ns.
    Mar 2011
    Los Angeles, California
    If you do a google search the device is manufactured by Supertex which has tech support: http://www.supertex.com/contact_app_engineer.html . There are also several sites that show equivelent devices as well as this site which shows who has a supply of the devices: http://www.ic2ic.com/search.jsp?sSea...106N5&prefix=V .
    Best, Ed
    Feb 2012
    PERTH AUSTRALIA
    thanks guys , will follow up on links and will apply math calcs
    cheers
