It can be EASY to check the OUT OF SYNC problem by having ONLY 1 of the PIC's with a resonator running and use the OSC output from the one running the resonator connected to the OSC input of one with out a resonator. There by both PIC's will be running at the EXACT same frequency. Unless there is some difference in the code running on each PIC they should not fall out of sync.
