Led blink and interrupt
Results 1 to 3 of 3
    Nov 2010
    Default Led blink and interrupt
    Hi.
    Can you help me with this:
    I have a 12F675. Pin 0 and 1 are connected LEDs. On pin 2 and 3 are related buttons.
    - If I press the button 2 LED 0 blink 10 times at 1s.
    If, as do those LED 0 blink, if I press the button 3, I would like to stop LED 0, and wait for pressing button again.
    - If I press the button 3 LED 1 blink 10 times at 1s.
    If, as do those LED 1 blink, if I press the button 2, I would like to stop LED 1, and wait for pressing button again.
    Can you help me with some examples?
    Thanks in advance.
    Cristi
    Default Re: Led blink and interrupt
    Quote Originally Posted by critix View Post
    Hi. Can you help me with this: I have a 12F675. Pin 0 and 1 are connected LEDs. On pin 2 and 3 are related buttons. - If I press the button 2 LED 0 blink 10 times at 1s. If, as do those LED 0 blink, if I press the button 3, I would like to stop LED 0, and wait for pressing button again. - If I press the button 3 LED 1 blink 10 times at 1s. If, as do those LED 1 blink, if I press the button 2, I would like to stop LED 1, and wait for pressing button again. Can you help me with some examples? Thanks in advance. Cristi
    Hi Christi, Sounds like you are building an auto signal, did that myself. set up a for next counter to blink your Leds. The interrupt should direct your counter variable to exit the loop by fulfilling the expected value I E 10 in this example, or without using an interrupt you could poll the input pins for change. UNTESTED example:
     i var byte
     if gpio.2 = 1 then gosub blink1
     if gpio.3 = 1 then gosub blink2
    'subroutines below
     blink1:
    pause 300 ' debounce time
     for i = 0 to 9  'set up blinker
    if gpio.2=1 then i = 10  'check for reset
    if gpio.3=1 then i = 10
     gpio.0 = 1  'turn on
     gpio.0 = 0 'turn off
     next i      'next count
    gpio0=0    'make sure light off b4 exit
      blink2:
    pause 300 'debounce time
     for i = 0 to 9
     if gpio.2=1 then i = 10 'check for cancel
     if gpio.3=1 then i = 10 'check other switch
     gpio.1 = 1
     gpio.1 = 0
     next i
    gpio.1=0 'make sure light off b4 exit
     return ' to main loop
    Nov 2010
    Yes, I want to build an auto signal. You did one?
    Can you give me your code?
