Hi All!
So there is a PIC program that someone else wrote that I am trying to get to work. Dannel was good enough to post a wonderful ICD program that works really great! Thanks Dannel! So I started by creating a simple "blink an LED" program so I know that except for this program an 18F1320 will work and that everything else is set up and configured correctly. So I go to compile this program, it compiles without any errors, program the 18F1320 and as far as I can seem to get is for everything to run up to the very first line of code "TRISB = %10000001 : TRISA.3 = 0". Then the ICD stops and will not restart and only gives the message I have grown to hate "ICD Connection Timeout". Now unless you re-compile and try running it again, nothing seems to run! There are two CONFIG sections in the program below, the first (commented out) will allow things to start up, the second goes directly to the connection timeout error! At this point I am beyond simple confusion. Thanks in advance, Ed
'* Name : Depth.bas *
'* Author : Ed Cannady *
'* Notice : Copyright (c) 2011 [select VIEW...EDITOR OPTIONS] *
'* : All Rights Reserved *
'* Date : 4/4/2011 *
'* Version : 1.0 *
'* Notes : For a 18F1320 and MS-5541 *
Include "Modedefs.bas"
define Loader_Used 1
DEFINE OSC 20 'Define crystal frequency
;18F1320 EXT OSC RUNNING AT 20MHZ TO 40MHZ MCLR AS INPUT AND OSC PINS AS INPUTS
' ICD config that starts to work
'#CONFIG
' __CONFIG _CONFIG1H, _HS_OSC_1H
' __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_32K_2H
' __CONFIG _CONFIG4L, _LVP_OFF_4L
'#ENDCONFIG
' Source Program Config settings
#config
__CONFIG _CONFIG1H, _HS_OSC_1H & _FSCM_OFF_1H & _RC_OSC_1H
__CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _BORV_27_2L
__CONFIG _CONFIG3H, _MCLRE_OFF_3H
__CONFIG _CONFIG4L, _DEBUG_OFF_4L & _LVP_ON_4L & _STVR_ON_4L
__CONFIG _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L
__CONFIG _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
__CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L
__CONFIG _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
__CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L
__CONFIG _CONFIG7H, _EBTRB_OFF_7H
#endconfig
'********************* Declaired Pins **************************
Clk var PortA.0
Dout VAR PortA.1 'data out from the MS5541
Din var PortA.2 'data in to the MS5541
Sclk var PortA.3 'MS5541 32.768 khz clock
Mclk var PortB.1 'MS5541 Master clock for the MS5541
'************************* Defines *****************************
DEFINE DEBUG_REG PORTB 'Debug output pin port
DEFINE DEBUG_BIT 6 'Debug output pin bit
DEFINE DEBUG_BAUD 19200 'Debug baud rate
DEFINE DEBUG_MODE 0 'Debug mode: 0 = True, 1 = Inverted
'************** Intersema Variables *********************************
C1 var word ' 5540 Pressure sensitivity
C2 var word ' 5540 Pressure Offset
C3 var word ' 5540 Temp Coef of pressure sensitivity
C4 var word ' 5540 Temp Coef of Pressure Offset
C5 var word ' 5540 Reference temperature
C6 var word ' 5540 temp coef of Temp reading
' C1 to C6 are in EEROM as VAL.byte0, VAL.byte1 from 108 to 159
D1 var word ' raw pressure word from Intersema sensor
D2 var word ' raw temperature word
D1Flag var bit
W1 var word 'coefficient from 5540
W2 var word 'coefficient from 5540
W3 var word 'coefficient from 5540
W4 var word 'coefficient from 5540
' W1 to W4 are NOT stored in EEROM - they are not needed again.
dT var long ' intermediate calc value
dT1 var long ' intermediate calc value
dT2 var long
UT1 var word ' Calibration temperature
II var byte ' used ONLY within Intersema routines
IJ var byte
IK var byte
IL var byte
ILoop var word
CalFlag var bit ' EEROM 99. Used to reduce wear on EEROM
temp2 var word
' General purpose Intersema and DS1629 RTC/Temperature variables
ClkChk var word ' = 8192 if IntRC clock is exactly on frequency
TimeFlag var bit
TempRead var word
CntRem var word
CntPerC var word
d var BYTE[18]
IW var long
IX var long
IY var long
IZ var long
T2 var long ' Second order Temperature correction
P2 var long ' Second order Pressure correction
Offset var long
Senstvty var long
Pressure var long '
Celsius var long 'a LONG allows negative temperatures
goto endofsubroutines ' jump subroutines at startup
'*************************** Subroutines *****************************
ResetIntersema:
' need 32768 @ 50% for Intersema on CCP2.
TRISB = %10000001 : TRISA.3 = 0 'DIn, DOut & SClk (Where is stops!)
' high presspwr : pause 100 : hpwm 2, 127, 32767 : pause 50
shiftout din, sclk, 0, [85, 85, 0\5] ' Sense of Din is IN to 5541
pauseus 100
FetchWord:
shiftin dout, sclk, 2, [ij, ii, ik\1]
' IJ is hi byte, II is lo byte, IK is a dummy and discarded
CalSensor:
read 99, calflag : if calflag = 1 then calsensordone
debug 13, 10, "Fetch Intersema data", 13, 10
' This fetches and unpacks the factory calibration coefficients
' from W1 ~ W4. W values need not be stored.
' These bitmaps are unpacked into the 6 working coefficients
' C1 to C6 which must be stored in EEROM for later use.
' W1
gosub resetintersema
shiftout din, sclk, 0, [87, 1\5] ' Send W1 pattern to all sensors
gosub fetchword ' get reply
W1.byte0 = ii
W1.byte1 = ij
' W2
shiftout din, sclk, 0, [215, 0\5] ' Send W2 pattern
gosub fetchword
W2.byte0 = ii
W2.byte1 = ij
' W3
shiftout din, sclk, 0, [55, 1\5] ' Send W3 pattern
gosub fetchword
W3.byte0 = ii
W3.byte1 = ij
' W4
shiftout din, sclk, 0, [183, 0\5] ' Send W4 pattern
gosub fetchword
W4.byte0 = ii
W4.byte1 = ij
' Unpack W1 ~ W4 into C1 ~ C6 coefficients
' C1
C1 = W1 >> 3
write 108, c1.byte0
write 109, c1.byte1
' C2
C2 = ((W1 & %0000000000000111) << 10) + (W2 >> 6)
write 110, c2.byte0
write 111, c2.byte1
' C3
C3 = W3 >> 6
write 112, c3.byte0
write 113, c3.byte1
' C4
C4 = W4 >> 7
write 114, c4.byte0
write 115, c4.byte1
' C5
C5 = ((W2 & %0000000000111111) << 6) + (W3 & %0000000000111111)
write 116, c5.byte0
write 117, c5.byte1
' C6
C6 = W4 & %0000000001111111
write 118, c6.byte0
write 119, c6.byte1
' high pgc : pause 1
' debug "Intersema Factory data ", $0D, $0A, "W1 = ,"_
' , #w1, ", W2 = ,", #w2, ", W3 = ,", #w3, ", W4 = ,", #w4, $0D, $0A
' debug "Derived coefficients", $0D, $0A, "C1 = ,", #C1, ", C2 = ,", #C2,_
' ", C3 = ,", #C3, ", C4 = ,", #c4, ", C5 = ,", #C5, ", C6 = ,", #C6.byte0,_
' $0D, $0A
' read 99, calflag : if calflag = 0 then write 99, 1
CalSensorDone:
ReadIntersema: '
' D1 is Pressure - D2 is Temperature
' Uses LONG datatype to handle negative temperatures
' This routine reads the sensor and returns Pressure word
' and Celsius long
' A, II, IJ, W and X are all destroyed
' D1
shiftout din, sclk, 0, [47, 0\5] ' Select D1 pattern
While dout = 1 : wend 'Convert5541Delay:
gosub fetchword
' This returns ii = lobyte, ij = hibyte from the sensor
D1.byte0 = ii
D1.byte1 = ij
' D2
shiftout din, sclk, 0, [79, 0\5] ' Select D2 pattern
gosub fetchword
D2.byte0 = ii
D2.byte1 = ij
CalcTempPress: ' 32 bit signed arithmetic version. Handles negatives.
read 108, c1.byte0
read 109, c1.byte1
read 110, c2.byte0
read 111, c2.byte1
read 112, c3.byte0
read 113, c3.byte1
read 114, c4.byte0
read 115, c4.byte1
read 116, c5.byte0
read 117, c5.byte1
read 118, c6.byte0
' formulae for DS5541 are NOT the same as for DS5540
ut1 = 8*c5 + 10000
dt = d2 - ut1
Celsius = 200 + dt*(c6 + 100)/2048
offset = c2 + ((c4 - 250)*dt)/4096 +10000
senstvty = c1/2 + ((c3 + 200)*dt)/8192 + 3000
pressure = (senstvty * (d1 - offset))/4096 + 1000
' NOT applying second order temperature correction in this version.
' Note 2nd order correction formula ambiguity in datasheet.
if celsius < 0 then 'high bit of 32 bit number is set
temp2 = 1000 - celsius
temp2 = 1000 + celsius
d[17] = temp2.byte0
d[18] = temp2.byte1
if calflag = 0 then
debug "MS5541 Celsius = ", sdec Celsius/10, ".", dec1 celsius//10, _
", Pressure = ", dec pressure, " mBar, recorded as ",_
dec temp2, 13, 10
EndOfSubRoutines:
' *********************** Initialise *****************************
FetchDepth:
gosub readintersema
' debug "T2 = ", dec temp2, 13, 10
debug dec (temp2 - 1000)/10, ".", dec1 (temp2 - 1000)//10, _
", ", #pressure, " mBar", 13, 10
' this returns Pressure & Celsius, both words.
