Display graphical font using Nokia3310LCD
Results 1 to 14 of 14
    Jun 2011
    Philippines
    Default Display graphical font using Nokia3310LCD
    Hi everyone!
    I managed to run a demo application by Steve using the NokiaGLCD wrapper(http://www.picbasic.co.uk/forum/show...ght=3310+Nokia).
    Here is the sample code I'm uisng..
            '--------------------------------< HelloWorld_16F877 >--------------------------------------
            '       File name  : HelloWorld_16F877.pbp
            '       Version    : 1.0
            '       Company    : Mister E
            '       Programmer : Steve Monfette
            '       Date       : JULY 27, 2011
            '       Device     : PIC16F877 @20MHz
            '---------------------------< Project description >-----------------------------------------
            '       Basic code example to display the usual Hello World on the NOKIA GLCD.
            '       This also show how to declare/use some of the GLCD_NOKIA.PBP Defines
            '       Compile: 1057 words
            '       Pic Configuration
    '@       __CONFIG _HS_OSC & _WDT_OFF & _PWRTE_ON & _BODEN_ON & _LVP_OFF
            DEFINE OSC 20
            '       Hardware assignment & configuration
            		'		GLCD
                            ' those are not needed as they're exactly the default one,
                            ' but it show how to use/declare them.
            		DEFINE GLCD_SCE   PORTB,4
            		DEFINE GLCD_RES	  PORTB,3
            		DEFINE GLCD_DC    PORTB,5
            		DEFINE GLCD_SDO	  PORTB,6
                    DEFINE GLCD_CLK	  PORTB,7
                    DEFINE GLCD_CONTRAST 65
            		DEFINE GLCD_TEMPERATURE_COEFFICIENT 2
            		DEFINE GLCD_BIAS 3
                    '       PORT
                    TRISB = 0 ' By default the Driver will use PORTB... all output to these then
                    PORTB = 0 ' clear the output/reset the GLCD
            '       Includes
            INCLUDE "..\Include\GLCD_NOKIA.PBP"    ' Plug the Nokia Driver/Wrapper in here
            '------------------------------< Main program >---------------------------------------------
            GLCD_CLS     ; Clear the screen (if not initialized yet, it will do automatically)
            GLCDOUT_AT?STR 0,0,"Hello World!"   ; Show String on Line 0
    Here:   GOTO Here   ' sit & spin
    My question is how can I display a font like the one below(please see attached image) this the hex equivalent...
    $08, $E0, $00, $E2, $01, $EE, $02, $62, $02, $06, $02, $0E, $03, $FC, $01, $F0, $01, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00, $00 ; for letter m
    Hope anyone can give me a hint on this.
    Thanks in advance,
    tacbanon
    Default Re: Display graphical font using Nokia3310LCD
    Open the Include and check out ADDCUSTOMCHAR macro. That should be easy enough for a single character. If you want to build a whole new font set, then check the TABLE_SYMBOLS etc etc sections.
    Refer to HelloWorld_2_16F877.pbp
    Also check out the Readme.txt file located in ...NokiaGlcd\Document folder. There's a short example how to use ADDCUSTOMCHAR macro.
    Jun 2011
    Philippines
    Thanks Steve for the response, I'm still figuring it out how it works(by trial and error ) and learn it in the process..I will post here my result.
    regards,
    tacbanon
    Jun 2011
    Philippines
    I'm still stuck with this simple code I modified from Steve's NokiaGlcd examples..
    	DEFINE GLCD_CHAR_IN_EEPROM			   ' store/read character/lookuptable to/from EEPROM
    		DEFINE GLCD_STRING_IN_EEPROM		   ' store/read string to/from EEPROM
    		DEFINE GLCD_USE_SPECIFIC_CHARACTER	   ' We will define our own set of character to be used
    		CHARTABLESTART
    				ADDCUSTOMCHAR CHR_CUSTOM_0, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
    				ADDCHAR 'e'
    				ADDCHAR 'l'
    				ADDCHAR 'o'
    				ADDCHAR 'w'
    				ADDCHAR 'r'
    				ADDCHAR 'd'
    				ADDCHAR '!'
    		CHARTABLEEND
            GLCDOUT_AT?STR 0,1,"Wello World!"   ; Show String on Line 1
            GLCDOUT_AT?STR 0,2,"j"   ; Show String on Line 2
    Here:
    as I understood characters not defined within CHARTABLESTART and CHARTABLEEND will not be displayed...but I'm still having trouble displaying this character (j) 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
    any idea what I'm missing?
    regards,
    tacbanon
    read again the readme.txt file example ...
    you have 2 extra argument in ADDCUSTOMCHAR, here you should have
    not
    Jun 2011
    Philippines
    it compiled with no problem now, but custom character won't display on the lcd, probably I'm still doing it wrong..
    I'm expecting a letter 'j' in the 3rd row.
    		CHARTABLESTART
    				ADDCHAR 'e'
    				ADDCHAR 'l'
    				ADDCHAR 'o'
    				ADDCHAR 'w'
    				ADDCHAR 'r'
    				ADDCHAR 'd'
    				ADDCHAR '!'
    		CHARTABLEEND
            GLCDOUT_AT?STR 0,2,"j"   ; Show 'j' on Line 2
    Here:
    I appreciate the time for helping out.
    regards,
    tacbanon
    You'll see a J once you'll add it in the character you want to use.... no coincidence why you don't have the H nor the W either
    Again it's all explained in the Readme.txt file...
    Jun 2011
    Philippines
    Angry character not displaying correctly to the glcd
    I'm trying to display a 10x11 font size "w" but not displaying right to the lcd...(sorry if I'm very slow catching up )
    						CHARTABLESTART
    								ADDCHAR 'T'
    								ADDCHAR 'E'
    								ADDCHAR 'X'
    								ADDCHAR 'a'
    								ADDCHAR 'b'
    								ADDCHAR '!'
    								ADDCHAR CHR_NUMBERS
    								ADDCUSTOMCHAR CHR_CUSTOM_0,0x04,0x88,0x01,0x48,0x01
    								ADDCUSTOMCHAR CHR_CUSTOM_1,0x28,0x01,0x18,0x01,0x00
    								ADDCUSTOMCHAR CHR_CUSTOM_2,0x00,0x00,0x00,0x00,0x00
    								ADDCUSTOMCHAR CHR_CUSTOM_3,0x00,0x00,0x00,0x00,0x00
    								ADDCUSTOMCHAR CHR_CUSTOM_4,0x00,0x00,0x00,0x00,0x00
    						CHARTABLEEND
            GLCDOUT_AT?CHR 1,0,CHR_CUSTOM_0
            GLCDOUT_AT?CHR 2,1,CHR_CUSTOM_1  ; Show String on Line 0
            GLCDOUT_AT?CHR 3,2,CHR_CUSTOM_2
            GLCDOUT_AT?CHR 4,3,CHR_CUSTOM_3
            GLCDOUT_AT?CHR 5,4,CHR_CUSTOM_4
    Here:
            '       Includes
            define GLCD_CHAR_6X8
                    CHARTABLESTART
                            ADDCHAR 'T'
                            ADDCHAR 'E'
                            ADDCHAR 'X'
                            ADDCHAR 'a'
                            ADDCHAR 'b'
                            ADDCHAR '!'
                            ADDCHAR CHR_NUMBERS
                            ADDCUSTOMCHAR CHR_CUSTOM_0,0x78,0x80,0x60,0x18,0x60,0x80 ;
                            ADDCUSTOMCHAR CHR_CUSTOM_1,0x78,0x00,0x00,0x00,0x00,0x00 ;
                            ADDCUSTOMCHAR CHR_CUSTOM_2,0x00,0x01,0x00,0x00,0x00,0x01 ;
                            ADDCUSTOMCHAR CHR_CUSTOM_3,0x00,0x00,0x00,0x00,0x00,0x00 ;
                    CHARTABLEEND
                    GLCDOUT_AT?CHR 0,0,CHR_CUSTOM_0
                    GLCDOUT_AT?CHR 1,0,CHR_CUSTOM_1
                    GLCDOUT_AT?CHR 0,1,CHR_CUSTOM_2
                    GLCDOUT_AT?CHR 1,1,CHR_CUSTOM_3
                    GLCDOUT_AT?STR 5,6,"TEXT!"
    Jun 2011
    Philippines
    Finally got it...thanks for the help.
    Way cool
    Thanks and Enjoy!
    Jun 2005
    West Australia
    Hi Tacbanon,
    Did you manage to create bigger fonts with Steve's program?
    I see your last post shows the display with obvious different font but still within the 6x8 field. How does one make a larger font exceeding this area?
    I'd appreciate your help and maybe a snippet of code if you've been successful. My aim is to make really big fonts (0-9, +, -, decimal point mid-height, C, F and degree symbol) in a 12x16 or 4 normal character size locations (7 chars per line, 3 lines) on the Nokia LCD using Steve's excellent wrapper. If it can't be done I can do other mapping but then lose Mister_e's utility.
    Steve if you're around perhaps you'd like to add some comments also? All help appreciated.
    Regards to all,
    Bill
    Jun 2011
    Philippines
    Hello Bill, sorry to tell you that I have not able to create a bigger fonts using Steve's GLCD...
    tacbanon
