can't even flash an LED
Results 1 to 8 of 8
    Dec 2003
    Wichita KS
    Hello John,
    JOhn>>
    CMCON = 7 ' Comparators OFF
    ANSEL = 0 ' A/D OFF -- Port pins all digital
    TRISIO = %00001000 ' All I/O but GPIO3 = outputs
    I added 2 zeros to your TRISIO, and changed the position of your GPIO.3 switch
    Loop:
    High GPIO.2
    Pause 500
    Low GPIO.2
    Pause 500
    goto Loop
    end.
    I could not check this out, because I am at work, but this should be very close to what you are looking for.
    DWayne
    Ability to Fly:
    Pilots that are Flying:
    bruno333's Avatar
    bruno333 Guest
    Default re: can't blink an LED
    Thanks for your help. I tried the code below, and it now flashes D2, D4, and D7 on the Pickit 1 board simultaneously. This thing is driving me nuts! Certainly you can symbol a specific output right?
    Loop: High GPIO.2 ' LED On
    Pause 3000 ' Delay 1/2 Second
    Low GPIO.2 LED Off
    goto Loop ' Forever
    Dec 2003
    Wichita KS
    Hello Bruno333,
    B>>Certainly you can symbol a specific output right?<<
    Yes, you can. But I wanted to give you the simplist of code to start out with.
    LEDPin var GPIO.2
    Loop:
    High LEDPin
    Low LEDPin
    Pause 500
    goto Loop
    Dwayne
    Ability to Fly:
    FYI TRIS statements are not necessary when you're using the PBP HIGH & LOW commands. PBP *automatically* sets the pin up as an output.
    If you use GPIO.2 = 1 or 0, then you'll need to first set the TRIS register to make this bit an output. If you use HIGH or LOW GPIO.2, then PBP sets GPIO.2 up as an output automatically.
    Why the PicKit board gives you odd results is due to the way the LED's are wired on the board. Look for the PicKit board schematic or download it here http://ww1.microchip.com/downloads/e...Doc/40051D.pdf
    Here's a simple BASIC example that strobes LED's D0 to D7 on the PicKit 1 board.
    @ DEVICE PIC12F675, INTRC_OSC, WDT_OFF, MCLR_OFF
    Define	OSCCAL_1K	1	' Calibrate internal oscillator
    ANSEL = 0 ' A/D OFF
    ' Modified from Microchip PicKit 1 state.asm demo source
    D0_D1	CON %00001111	; TRISIO setting for D0 and D1
    D2_D3	CON %00101011	; TRISIO setting for D2 and D3
    D4_D5	CON %00011011	; TRISIO setting for D4 and D5
    D6_D7	CON %00111001	; TRISIO setting for D6 and D7
    '; define LED state (what GPIO will equal)
    D0_ON	CON %00010000		; D0 LED
    D1_ON	CON %00100000		; D1 LED
    D2_ON	CON %00010000		; D2 LED
    D3_ON	CON %00000100		; D3 LED
    D4_ON	CON %00100000		; D4 LED
    D5_ON	CON %00000100		; D5 LED
    D6_ON	CON %00000100		; D6 LED
    D7_ON	CON %00000010	 	; D7 LED
    TIME VAR BYTE
        FOR TIME = 50 TO 200 STEP 25
            TRISIO = D0_D1 : GPIO = D0_ON
            PAUSE TIME : GPIO = D1_ON
            PAUSE TIME
            TRISIO = D2_D3 : GPIO = D2_ON
            PAUSE TIME : GPIO = D3_ON
            PAUSE TIME
            TRISIO = D4_D5 : GPIO = D4_ON
            PAUSE TIME : GPIO = D5_ON
            PAUSE TIME
            TRISIO = D6_D7 : GPIO = D6_ON
            PAUSE TIME : GPIO = D7_ON
            PAUSE TIME
        NEXT TIME
        GOTO Main
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    bruno333's Avatar
    bruno333 Guest
    Yeah, I just figured out the LED wiring of the Pickit a few minutes ago before I read your post. Very strange way to do things? I've used several development boards, and usually LED's are wired individually to the separate pins so you can quickly (and simply) check program operation. Why on earth did they do it this way? The LED's are wired with several forward and other's reverse polarity. Sure I guess you might want to experiment with Hi and low outputs... but geeze what a mess.
    Besides that, it's a nice programmer. No wall-wart, and 36 bucks.
    hehe that's what i often call an engineer trip. Bah that's doing food for your brain cells.
    I think the idea was to show creative appplication of limited resource devices like the 8 & 14-pin targets. It is a nifty board considering the investment.
    -Bruce
    tech at rentron.com
  1. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  2. LCD will not start
  3. I can't even make an LED flash!
    By George in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2007, 07:39
  4. Need help with write function
    Last Post: - 12th July 2006, 05:12
  5. elapsed time between two led flash...
    By dario in forum mel PIC BASIC Pro
    Last Post: - 5th February 2006, 17:09
