Decimal PWM Cycle values?
Results 1 to 3 of 3
    Default Re: Decimal PWM Cycle values?
    No, you can not produce a PWM signal with a LESS than one cycle - and that's not a PBP limitation. What you can do to make it fade up/down faster is to decrease the number of discrete dutycycles that it "passes thru" by using the STEP directive in the FOR-NEXT loop, like you do when fading down
    For Duty = 0 to 255 STEP 5
       PWM LED_0, Duty, Clycle
    NEXT
    Or you could increase the oscillator frequency which in turn will increase the frequency generated by the PWM command.
    Thanks Henrik, I'll give your suggestion a try. My only concern is that I don't want flickering.
    BTW, I'm already using a 20Mhz crystal.
