Decimal PWM Cycle values?
Results 1 to 3 of 3
    Default Decimal PWM Cycle values?
    (Very much a self-proclaimed noob so please bear with me)
    I'm trying to blink an LED to simulate an old incandescent bulb using PWM but want the fade in/fade out part to be a little bit faster than CYCLE = 1 (in the future, I want to use some pots to be able to control this speed on the fly, but I'm not there yet). Is it possible to use values of CYCLE < 1 with PWM and a 12f629?
    DUTY VAR BYTE
    CYCLE VAR BYTE
    LGHTS_ON_MS CON 1500
    LGHTS_OFF_MS CON 500
    Cycle = 1
    lblLoop:
        ' Fade in
        For Duty = 0 TO 255
           PWM LED_0, Duty, Cycle
        Next
        High LED_0
        ' Stay on LGHTS_ON_MS
        Pause LGHTS_ON_MS
        ' Fade out
        For Duty = 255 TO 0 STEP -1
        Next
        ' Stay off for LGHTS_OFF_MS
        Pause LGHTS_OFF_MS
        GoTo lblLoop
    Default Re: Decimal PWM Cycle values?
    No, you can not produce a PWM signal with a LESS than one cycle - and that's not a PBP limitation. What you can do to make it fade up/down faster is to decrease the number of discrete dutycycles that it "passes thru" by using the STEP directive in the FOR-NEXT loop, like you do when fading down
    For Duty = 0 to 255 STEP 5
       PWM LED_0, Duty, Clycle
    NEXT
    Or you could increase the oscillator frequency which in turn will increase the frequency generated by the PWM command.
    Thanks Henrik, I'll give your suggestion a try. My only concern is that I don't want flickering.
    BTW, I'm already using a 20Mhz crystal.
