Help with look up table
Results 1 to 8 of 8
    brighton
    Default Help with look up table
    Hello All
    i have a big problem on my hands which i ned some help with.
    i have got the following data which comes from a sensor and i need to calibrate this to Bar.
    the sensor outputs period in uS and the corresponding pressure i need to equal this to are below
    PERIOD PRESSURE IN BAR
    324.7
    327.8
    0.25
    330.8 0.5
    335.1 0.75
    338.2 1
    341.6 1.2
    346 1.4
    350.5 1.6
    354.5 1.8
    359.3 2.0
    363.7 2.2
    369.7 2.4
    374.1 2.6
    379 2.8
    386.4 3.0
    my question is what is the best way to approach this .
    should ido it with lots of if then statements of have you guys got a better way i can do this
        if period <=  325 then
        pressure = 0
        if period >  325 and period < 328 then
        pressure = 0.25
         if period >  328 and period < 330 then
        pressure = 0.5
        if period >  330 and period < 33 then
        pressure = 0.25
    Best Regards
    Isaac
    May 2008
    Italy
    Default Re: Help with look up table
    Isaac, you can tray with the regression coefficient.
    Pulse VAR word
    Pressure VAR word
    Dummy VAR word
    Slope con 476
    Inter con 15
    Dummy = Pulse x Slope
    Pressure = Div32 10000
    Pressure = Pressure - Inter
    This will give you a 10% drift but it could be acceptable.
    Cheers
    Al.
    brighton
    Thanks for you help
    i am work on this at the moment
    but not sure its going to work out right
    would test tomorrow
    regards
    Isaac
    datax var word
    pressure var word
    Get_Pressure:
    if (datax <= 325) then pressure =0
    if (datax <= 328) and (datax > 325) then pressure = 25
    if (datax <= 331) and (datax > 328) then pressure = 50
    if (datax <= 336) and (datax > 331) then pressure = 75
    if (datax <= 339) and (datax > 336) then pressure = 100
    if (datax <= 342) and (datax > 339) then pressure = 120
    if (datax <= 346) and (datax > 342) then pressure = 140
    if (datax <= 351) and (datax > 346) then pressure = 160
    if (datax <= 355) and (datax > 351) then pressure = 180
    if (datax <= 360) and (datax > 355) then pressure = 200
    if (datax <= 364) and (datax > 360) then pressure = 220
    if (datax <= 370) and (datax > 364) then pressure = 240
    if (datax <= 375) and (datax > 370) then pressure = 260
    if (datax <= 379) and (datax > 375) then pressure = 280
    if (datax <= 387) and (datax > 379) then pressure = 300
    if (datax < 323) or (datax > 389) then pressure = 999
    Not sure if it's better, but the title was about a LOOKUP table ...
    Idx      VAR BYTE
    Get_Pressure:
        LOOKDOWN2 datax,<=[322,325,328,331,336,339,342,346,351,355,360,364,370,375,379,389,65535],Idx
        LOOKUP2       Idx,[999,  0, 25, 50, 75,100,120,140,160,180,200,220,240,260,280,300,  999],pressure
    Isaac, I think I would do it this way, eliminating the AND in each of the statements by using a CASE statement. I also notice there is no compare for the value of 389. Is this intentional?
    select case datax
    case is < 323
    pressure = 999
    case is < 326
    pressure = 0
    case is < 329
    pressure = 25
    case is < 332
    pressure = 50
    case is < 337
    pressure = 75
    case is < 340
    pressure = 100
    case is < 343
    pressure = 120
    case is < 347
    pressure = 140
    case is < 352
    pressure = 160
    case is < 356
    pressure = 180
    case is < 361
    pressure = 200
    case is < 365
    pressure = 220
    case is < 371
    pressure = 240
    case is < 376
    pressure = 260
    case is < 380
    pressure = 280
    case is < 388
    pressure = 300
    case is > 389
    pressure = 999
    end select
    EN82fn
    Apr 2007
    Pennsylvania, USA
    For what it's worth, in my experiences, using IF THEN commands compile to a smaller file size than using the CASE command. That said, I would use a lookup table as Darrel provided an example.
    What sensor are you using?
    Shawn
